Need help with FAST XFI.
Ty 1885
XFI saying that i am at 100% injectors duty cycle with only 40% go pedal, maybe 10psi boost.
I have new fuel tank with rear sump, 10an line to Aeromotive filter - A1000pump - Aeromotive filter - 8an braded line to 8an adapter- stock rail, rpm GN regulator, 3/8 (stock feed line) for return to tank, #85 injectors.
Fuel gauge reads fine with 43psi base, 1psi=1psi boost.
WB reads fine with 11.5 - 11.8 AFR.
XFI is adding 24% fuel.
I'm thinking two things:
1) I'm running 10g wire from alt to relay (near pump), the neg wire to XFI is 16g (stock pos wire that feed the stock pump). Could the 16g wire be too small causing a resitance ?
2) I'm using wire from stock wg relay to activate pos side of injectors, wonder if its droping voltage ?
Any ideas ???
turbodig
Re: Need help with FAST XFI.
If your WOT fuel pressure is ok, your pump is delivering enough fuel.
Possible that your injectors aren't wired properly or powered properly.
Possible bad injector(s).
Also possible that the wide-band is lying to you.
Try Me
Your wide band says that is the a/f ratio, what is the actual xfi seeing? Also what is your Target A/F at that point in the graph? Maybe the target a/f ratio is set at something crazy like 6:1 making the xfi want to add more fuel to meet the desired ratio.
At +24% correction that has to be maxed out so something is making the xfi think you are waaaay leaner than your target a/f. If your tune is good you should never have more than 5% +- correction.
Windedv6
Ty n 10s
I had the same problem. Lance is looking into it as it may be in the program. Check your pulse width. It is probably very low. Your injector PW can go to mid twenties and you are probably only doing 10 to 12 PW. Duty cycle % is a calculation from a couple of different points in the program. I run mine with my pulse width around 18 -20 WOT and 100% duty cycle. The injector still has plenty of additional pulse width to still use. I never show a lean condition in my AFR readings.
Henninger found the problem when we switched to the lastest frimware. The V8 program is correct, but the V6 DC calc seems to be off. I will follow up with Henninger and Lance and see if anything as been corrected.
John
Ty 1885
Thanks guys. I hope its the program because i'm pulling my hair out trying to fugure this thing out
