need help with intake manifold bolts
2500avalanche
Well-known member
I am in the process of re assembleing the motor before they take it for paint.
I got all new gaskets, but I see that the bolts for the intake manifold some are different length.
Can someone tell me the correct location for the longer bolts?
Thanks
NJ93TY
Re: need help with intake manifold bolts
The longer ones go through the little engine brackets to lift the engine I believe.
NJ93TY
Yes but not sure if it's drivers front and pass rear or switched.
Quickstop [UK]
Combating adversyty.
IIRC the short ones are into the passages at the 4 corners of the block. Have you got the
manual? The bolt layout is in there I think.
Shouldn't be too hard to mock it up no?
