Need help with reassemble - Pomona
Espritmike
I am putting my Typhoon motor back in (well my helper at the shop is) and having trouble with where intake studs, brackets etc. go.( Truck came apart in July) Can't seem to find good pics. If someone is in the area could come by (1 mile norht of Pomona fairgrounds) and just peek under the hood, I would really appreciate it. In return, you can run your truck up on the rack, check emissions on smog machine,Change your own oil, whatever. Call me Mike (909)576-4337 thank
Re: Need help with reassemble - Pomona
Drivers side rear and 3rd from the rear are the coil support. Front drivers side gets a studded bold as well for the grounds. Pas side rear is engine lift bracket. 3rd from the rear, pas side is center support for upper IC. Front 2 AC support.
HTH
Espritmike
I knew about the coil bracket. I thought the engine lift was on the front of drivers side(ooops). I also have close up pic of the passenger front bracket. Now the intercooler has 3(?) brackets right?. 2 off of the exhaust manifold in the (* X * * X *) "X" = stud positions and the one on the intake? Correct. Thanks
There may have been a lift bracket up front as well, don't remember. I'd leave the back one off. It's just in the way.
Fighting5thSVT
I'm not sure if any of these will help, but here they are anyway. Good luck!
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
I have a handful more if you would like me to PM them to you.
Quickstop [UK]
Combating adversyty.
Post a pic of them and we can probably tell you were they go...
Sorry to :hijack: but I PM'd you about the Hex bolts you're selling and no reply.
Back to the thread.... What he said - pst pics so we can identify the brackets.
SY2932
Administrator
I replied to your PM over the weekend. I just looked at my sent PM's and I see a sent message to you on 1/28/11 @ 2:36 PM that doesn't have anything other than your original message FANTASTIC :roll:... Yes, I have several sets ready to ship.
Espritmike
Okay, Im set to post pics. So here goes. I think the first one might just be a trans cooler line bracket. Sorry i'm not that computer saavy. Mike
Quickstop [UK]
Pic 1 is part of the bracket that holds the oil filter lines to the PS pump. 2 and 4 are not stock.
Espritmike
I think pic. #1 is some trans line bracket (looks too small for the oil cooler lines, Pics 2 and 4 were bead blasted so no longer are black and I disassembles te whole front of the vehicle (except core support), so those may be some brackets for the battery tray, or cruise control ?
Haven't figured out 2 & 3 but 1 & 4 go together. I think. :rotf: And yes, support for the oil filer/cooler lines as they come past the PS pump.
Espritmike
Thanks Don, I think you are right. It seems to bolt to the front of the p/s pump and hang down and mount to the cooler lines. one left????
