Need help with some datamaster stuff...
LBoogie
Boost Addict
Ok so I went out and did a few short runs after putting in the Ultimate and afpr. Couple of questions...first, my tps% never goes to 100, goes up to about 75% when I have it floored. What could be causing this? Second, I don't really know what my fuel pressure should be set at, all the posts I searched through are saying anywhere between 42 and 50 psi, right now I have it at 43...I had it at just 50 and it seemed to be a little sluggish so I lowered it some. also My LTerm counts are up around 150, I know they should be down around 128, I dont know why this is so high. Any help would be greatly appreciated.
students.db.erau.edu/~hatch672/oct18.uni <--this is the run (I couldn't really get up to a high speed, but its all I got right now.)
LBoogie
Boost Addict
Re: Datamaster...
Re: Datamaster...
I also had a boost spike up to almost 20psi, which was accompanied with 10 degrees of KR...I was just out looking at wastegate rod, and there is a hard metal a/c line going down right past the wastgate rod. The end of the wastegate rod is scraping on this (why it is that close to begin with I have no idea :roll: ). I am guessing this is the reason for the spike and KR...still need help with the other stuff though...
mrweelr
Re: Need help with some datamaster stuff...
Well, your engine is definitely running too hot. Try tossing in a 160F thermostat and getting those underhood temps down. The TPS not going to 100% could be your floormat getting in the way of the pedal or your TPS is bad. Hopefully, you bent the AC line away from the wastegate rod. I think I had my base FP set to 45psi when I had a stock injector Ultimate.
