thanks to TT i finally got my ty running after 2 whole years of sitting. feels great to be able to drive it again. came close many times to selling to my friends but knew i'd regret it if i did.
first off, i still don't have datamaster nor do i have the scanmaster 3 so i am just hoping any of you can give me some areas to look at. i am just using my snap-on scanner for now. i plan on getting the scanmaster 3 when i get more fundage.
now me and my friend are stumped because we can not get the truck to boost past 3400 rpms. before i replaced the iac and plugs and reset timing to 0 (w/ est disconnected) i was able to go past 3400 rpms but the truck was running rich and blew out smoke from exhaust but that was just residual from sitting for so long. truck idled great and pulled fricken hard. iac was way off and plugs were fouled and timing was at 15 with est disconnected. truck did not set cel but did flash. believe it to have been knock.
replaced all that and now it will not go past 3400 rpms. just feels like it falls flat. i tried harder to get past that point and it backfired out the tail. no cel set or flash during this. no hood on so i know it wasn't the intake. under normal driving conditions there are no problems what so ever. no more smoking. iac is within spec and plugs are new tr6 set to .028 like always.
thinking map could be bad because with truck running i disconnected it and ty kept running with no stumble and no cel. cel does come on with key forward. someone suggested drac but that means nothing to me.
mods:
super 25g
delphi 50lb injectors
a2a
atr headers
vortec heads
ported upper and lower intake
walbro 255
cat delete
ebay billet distributor
turbo tweak chip
no msd 6a because it blew up
hallman mbc set below recommended 3/4" install setting
egr delete
thank you for your time. nick
mods:
super 25g
a2a
atr headers
vortec heads
walbro 255
cat delete
turbo tweak chip
egr delete
