need help with vacuum lines??
TNPhoon
1of28
Re: need help with vacuum lines??
Bottom one, not 110% sure, but probably the vac line that's supposed to be running to the firewall.
Flyin Ryan
hated cuz he drives fords
TNPhoon
1of28
2 on the left of pic 1 go together
2 on the right of pic 1, one w/ clip, don't use. One without clip goes to the WG below.
Still thinking pic 2 goes to the firewall because of where it's located in the truck with the pic.
burmeister
Today forecast High Winds
ok Im going to go out side a try those. hopefully this bitch will run soon. I still have to change oil and get the cap and rotor in. thanks for the info.
Flyin Ryan
Rob
That last pic of yours of the vacuum port isn't factory so you don't need it cap it off for now. I believe it was part of the atr waste gate setup or manual boost knob that ran to the wastegate on the old dp.
burmeister
thank you alot better that diagram is tuff if you dont know what your doing and thats my case.. the bottom valve is capped off?
Uploaded with ImageShack.us
