B
Blake
Guest
Merry Christmas, guys!
Finally got to start working on my WB Tech Edge kit and noticed that it does not come with a DB9 connector like Falco has here(on the lower right):
How do I hook this up to F14 on my ecm?
On the DB9 there are 3 pins used. One is for 12volt out, a ground, and the other is for the Vout signal from the wideband sensor. It looks like I only need to solder on the DB9 and take the Vout and run it to F14 on the ecm and not use the +12 volt and ground connections.
Am I looking at this correctly? I'm no electrical engineer by no stretch but this kit looks really easy to put together, just need get everything polarized correctly :-?
Thanks, everyone!
Blake
Thanks, everyone!
Blake
