Need help
RedTyFoon
Guys got a problem with the syclone...Slow cruise nail it around 20 mph makes boost but wont pick up any RPM or mph.....?...Tranny is fine?...Any ideas...I noticed with race gas the truck was getting alot of knock...Wonder if the knock sensor went bad and is causing it to pull everything out????? Anything would help...Completely lost...John
Hu Ryde
Re: Need help
Does it downshift or anything related?
Have you had the truck on a scan tool?
RedTyFoon
Re: Need help
It has been scanned a few wierd things but nothing outstanding...It just started out of the blue...No it does not down shift..The tranny is recently rebuilt. I have never had a minutes trouble out of it...Where is the knock sensor mounted?
EcSy#2671
Si vis pacem, para bellum
Re: Need help
The knock sensor or "ESC" is located on the back of the Engine just above the Transmission on the Driver side. In line with the Head.
Bill Z
Re: Need help
John,
Like they said above,
Does the transmission down shift?
Is your timming set to zero at idle with the sensor unplugged?
Did you plug your sensor wire back in?
Bring it by and let me look at it.
Bill
