Need help...
wantingasy
Re: Need help...
I couldn't find that post about all the stuff I should look for, so I just ran the TY for 28 mins and copied down all the numbers at idle. Hopefully someone can look at these and tell me if they look normal or what:
Engine Speed=700-750 RPM
Coolant Temp= 179 F
Coolant Temp at start-up= 64 F
Manifold Air Temp=131F
Manifold absolute pressure= 7Hg
Manifold Vacuum=26Hg
Barometric pressure= 30Hg
Throttle Sensor Voltage=.65VDC
Oxygen Sensor voltage= 140's-830's ( moves up and down really fast )
A/F ratio (commanded)=14.7:1
Air flow rate= 24.0 GPS
Volumetric efficiency=67% (with a couple of fast flashes in the 30's)
Injector pulse width= 1.6 ms
Wastegate duty cycle= 100%
Idle air position= 21/22#
Desired IAC position= 21/22#
Spark Advance=24.4 deg
Knock Retard=0.0 deg
Spark control counts=10#
Integrator=128#
Block learn multiplier=130#
EGR duty cycle= 0%
Battery Voltage= 12.1/12.4 VDC
Fuel mixture status= switches between lean/rich
Battery Status= Normal
Kind of long. I've only floored my TY a couple of times and one of them was when I was out this time and I looked down at the laptop and saw throttle position at 100% and it seemed like it wasn't going to shift!!!!!!!! So I let off a little and when it shifted it made a huge WHOOOSHHH sound which kind of sounded like air coming out of my filter and/or BOV!?!?!? Scared me.. Then I smelled fuel, but everything was running fine still. I hope somebody can help me out....
P.S. I checked the trouble codes and there were NONE
wantingasy
Re: Need help...
I figured out the big WHOOSHHHH sound....I had a tear in my IC hose. Could that cause it to not shift? I hope somebody helps me out with those numbers....The low voltage I think is my alternator going bad.... The truck idles rough when I turn on my lights....
SY2455
70's Veteran
Re: Need help...
I would change out that alternator if I were you, these truck don't do well on low voltage. If you are getting on it your trans should shift around 3800 - 4,000 rpm. Are you coming home for spring break? Maybe we can meet up if you got work to do on it.
wantingasy
Re: Need help...
My spring break was last week. I ended up going to Mt. Shasta snowboarding. I'll be back down there around May 14th. I'm going to buy a voltmeter tomorrow and test the alternator and some other stuff. I'm pretty sure it's the alternator, I'll find out tomorrow and if it is I'll be ordering the chrome 140 amp from RPM :tup: I need a little chrome under the hood anyways :lol:
SBNova
Re: Need help...
Dont know much about sy/ty ECM,s or their code, but my Vette running a '165 ecm has a bat voltage vs. injector pulse width modifier. Im not sure why GM would change fueling for different battery voltages, but it gets WAY richer with less battery voltage.
wantingasy
Re: Need help...
I bought a multimeter today and tested the voltage at the battery... With the engine off its at about 10.0 and when the engine is running it will only hit about 10.5 maybe 11.0. I'll also check the alternator probably tomorrow now that I know where to ground it at. Should the voltage at the alternator be about 14.0?
