Re: Need help...
Alright, here we go, I went and bought a power inverter today so I can run the laptop in my car. So I got everything hooked up and started up diacom. Immediately my rpms just went up to about 1300 and I don't know what to expect cause it's my first time using it so I figured that's normal. It started sounding like my car was pinging though. So I'm looking at all the stuff it's showing trying to figure out what's what and I don't think my knock is working. Is it labeled "knock retard"? Theres also this section I think is called advance timing....and it shows like 47.1!!!! I'm thinking that's not normal. So I take the ty out for a short drive and it drives wayyyyy differently when diacom is running. Like in drive the rpms are at like 1300 at a stop. I went around the block and came back and it shows trouble codes and there's like 5!!! I didn't write them down at the time but it was like: MAP sensor low, then there was a 35,34 and some other ones. I shut it off, go inside and get a paper and pen, come back and take it for another short drive to collect the numbers again and when I get back it only shows one code and that's 35 ( Idle air control error ) So I do it again a little bit later and the same error is there...So I think that's where I stand right now....Any suggestions/help/info on what I should do? Like I said this was my first time and I need to know how to work this thing..Thanks
