Need ideas for Blitz boost controller (*pics)
Syclone#1992
SyTy.net Moderator
Where do you guys mount the sylenoid in the engine bay? Where is the best place for the controller. Everything else is pretty much self explanitory.
Pics would help a lot.
Thanks,
Syclone#1992
SyTy.net Moderator
Oh yeah,
Does it do any harm to replace or eliminate the coolant orverflow for our trucks? {to make more room?}
QUIKSUV
I mounted the solenoid behind the grill close to the passenger side headlight. It fits in there nicely and will not be subject to heat. Lines route easily back to the turbo. I ran the wires across the front (behind the grill also) and then up the driver side, thru the firewall and into the interior.
Only thing to consider is it will be exposed to weather. Mine is not a daily driver so it was a nice, invisible place to install it.
Good Luck
myclone
I cut a piece of ~1/16" alum and made a bracket to mount it to an existing hole on the passenger side fender (an ex battery tray mounting hole). I put the selonoid box on the inside since I dont run fender wells to keep it dry should I get caught in the rain.
Heres a couple of pics I snapped to give you an idea (lets hope they work :roll: )
I know, I know.... I need to paint the bracket and clean under the hood.. I have a gravel driveway which makes keeping the truck clean on the outside it huge PIA let alone under the hood. I havent painted the bracket cause Im worthless (paint adds weight anyway :D ).
Syclone#1992
SyTy.net Moderator
Thanks thats a great idea. I think I am going to replace my overflow tank with a smaller unit and mount mine right on top of the fend as of now.
Myclone,
Where did you run the harness through on the firewall?
myclone
Syclone#1992 said:
Myclone,
I ran it through the grommett(sp?) that the radio antenna wire runs through that is located right below the heater box. Its close to the glove box too as thats where the control box is mounted. I ran the hand held adjustment/LCD display wire out of the corner of the ash tray.
HTH
Syclone#1992
SyTy.net Moderator
I decided to replace the coolant overflow bottle with a smaller one, and mount the Blitz Boost Sylenoid there. This unit is SWEET!! :D
mrweelr
You runnin' that controller in conjunction with an Ultimate or do you still have the stock chip? Do you have an external wastegate? Just wondering how it's working out since I haven't yet decided on using my Hallman MBC or going with a Blitz SBCid.
Syclone#1992
SyTy.net Moderator
KGB Pilot125 said:
what the heck is that big aluminium tank? is that your new overflow???
Its my new overflow. It is smaller and I was able to mount the Blitz easier and do a cleaner install. The aluminum tank is smaller than the stock 8)
I haven't got a chance to "try" it. I have it all hooked up and ready to go. I am just waiting for the weather to break and the salt to clear off the road.
What I like about the Blitz controller is you have 4 Channels to program the boost and gain (how fast the turbo spools). I will be running this combo with a TIAL 35 MM wastegate. I am running a modified stock chip with boost and EGR delete along with other minor changes. I am eventually going with a Dig Chip and 3 bar map. I will try it out once I get a chance.
I will keep you posted.
mrweelr
Re: Need ideas for Blitz boost controller (*pics)
Old thread, but just to update, I got my Blitz SBCidII yesterday. Looking forward to trying this baby out when my Sy transformation is complete :)
