B
BoostedGMC
Guest
I have been searching jegs, summit, and a few more places that sell AN fittings. I am having no luck with the searches though. I need to take the trans cooler line from the radiator and cut it about 6 inches down and connect it with a trans hose so it will clear the orange elbow that I rotated to add a k&n in place of the battery. With the stock hardline connected, the elbow has no room to rotate. I need a male/male AN adapter from 5/16 to -5an. then a -5 an 90 degree bend to hose barb. I was told 5/16 will screw into the trans cooler on the radiator. not sure if it is the feed or return, but it is the fitting directly under the radiator cap.
Next on the list is to connect the fuel pressure sender to the fuel rail. not sure exactly the sizes but would like a 90 right off the fuel rail to a braided hose. then a straight hose fitting connected to the sender. I am hoping I will have enough room to use a 90 on the rail. I don't know if the fuel rail is too close to the intake manifold. may have to just use a straight.
If you can find part numbers for these fittings it would be greatly appreciated. I can't seem to find what I am looking for. Thanks for your help. -Larry
