Need Part Number Black Ball????
Nasariobv
Ok so im buidling a new custom cold air intake, when i took the battery tray out it was preety bad (rusted out) or acid from the battery, what is the part number for the vacumm ball under the battery tray as it its broken and bad shape???
AlaskaTy
Re: Need Part Number Black Ball????
I don't know the p/n but you could go to a junkyard and get one for a lot less. Or you could just take it out, a bunch of members have done that.
InvisiBill
It's a standard S-truck part. Even the common clueless GM dealership should be able to find the number for you.
Loeryder
I took mine out, you are more than welcome to it.
$15 shipped.
The vacuum reserve ball stores vacuum so that when the engine is in boost the cruise and hvac controls still function normally, since they are vac controlled.
If you dont have one, then your HVAC controls will not switch from floor to defrost until you get out of boost.
There is NO competetive advantage of keeping it unless you just like the clutter.
Nasariobv
oh ok
oh ok
oh ok so i can go without it, i was curious as what the main function of it was. so no vacumm leaks if i take it out then??
syclonekid43
ok im lost here. i never hadone in my sy since day 1.
so i figured it never had one in there.
where should it be? not that im gonna put it in now. my cruise and everything else works fines.
will it effect spool time if the ball is out from a dead stop?
jwaller
Evil Genius/SyTy Guru
the vac ball is bolted to the bottom of the battery tray from the factory.
