Need Phil Long 75lb chip settings
denny
Can someone please give me the fuel / ]timing settings for Phil 75lb chip. I bought it used, so I don't feel right to contact Phil of turbotime.
2kwik4u
Resident slow guy
Re: Need Phil Long 75lb chip settings
I doubt you'll get much help. Giving out the tmiing/fueling setting on a chip pretty much eliminates the need for him to sell that chip.
Intellectual property is hard to protect, and I'd certainly think that most people here are credible enough to not just hand it out.
I'm sure the timing with the brown wire disconnected is supposed to be 0*, and fuel pressure is somewhere between 45 and 50psi base. Aside from those settings, good luck.
denny
Sorry I must be asking it wrong.
What I need is the paper that came with the chip , similar to below for Phil 75lb chips
T1 F1 Street timing (~14 deg at WOT), 18psi, WOT fueling setting 1 LEANEST
T1 F2 Street timing (~14 deg at WOT), 18psi, WOT fueling setting 2
T1 F3 Street timing (~14 deg at WOT), 18psi, WOT fueling setting 3
T1 F4 Street timing (~14 deg at WOT), 18psi, WOT fueling setting 4
T1 F5 Street timing (~14 deg at WOT), 18psi, WOT fueling setting 5 T1 F6 Street timing (~14 deg at WOT), 18psi, WOT fueling setting 6
T1 F7 Street timing (~14 deg at WOT), 18psi, WOT fueling setting 7 RICHEST
2kwik4u
Resident slow guy
AH.....Gotcha now.....I haven't seen that, nor do I know where to find it.
cloneman315
pm him or call eric at turbo time ,i would tell u mine but i know my 75 settings are different than all the others
denny
Cloneman, thanks,
I got it from Phil.
