Need pic on adjusting air leveler
ZavzTy547
Senior Member
Their was a pic back in the day that showed how to adjust the air leveler to compensate a 2-3 inch drop, without unplugging it . Anyone know were this pic is located?
Jimmy
Banned
Re: Need pic on adjusting air leveler
It's real simple.There is an arm on the actuater that can touch frame.When that arm touches the frame,it activartes the pump to raise the shocks so the arm doesn't touch the frame.
All you gotta do is adjust the arm to it's lowest position (i.e. not touching the frame) or bend it,chop it off,ect and the ride height will be 4X4 normal.
Or just pull the pump fuse.
turbodog
Ummm... this doesn't sound like the system on either of my Typhoons...
What I have (and what is in the manuals):
There is an arm on the sensor switch that extends out from the driver side frame rail over the pumpkin. There is a linkage from this arm down to the pumpkin. There is a small bracket on the pumpkin to which this linkage connects.
On my first Ty, I simply bent the linkage to effectively shorten it. I also had to adjust the arm connection to the sensor switch. This sort of worked, but poorly.
This is because, unlike the sketch, the end of the arm isn't directly above the pumpkin bracket. It runs on the diagonal:
and after bending (or shortening) the geometry really sucks. The up and down motion of the pumpkin does not result in the same up and down motion of the sensor arm. Ride height is very un-repeatable.
For my current setup, I did more extensive modifications to make it work right.
If you're after a simple solution, best to unplug the ELC and run regular shocks. My current setup is not a simple solution, but it does work.
#1611 - Ty
New and loving it!
If you don't want to bother with bending arms and doing all that, Like I didn't. You can try this.
Parts:
Inline spade fuse holder
Momentary switch
spade connectors
To Do:
get under the dash and find the load leveling fuse
Pull it out
Crimp one spade connector to oneside of the fuse holder
Solder the switch to the other side of the holder
Then connect another wire to the other side of the switch
Finally connect another spade connector to the end of that wire
Put the spade connectors where the fuse should be (doesn't really matter which way it goes in as long as it doesn't touch each other)
NOW... you can start the truck.. and when your loaded.. you can hit the switch for a few secs.. level it out.. and your GOLD!... When you leave the switch off for a while... it'll settle back down.
That's my simple way.. Hope that helps
Wilson
ZavzTy547
Senior Member
turbodog said:
Yup. Simple and effective.
It's nice to know that I'm not the only one on the board that still has the air ride and likes it
Big thanks to Jimmy, TurboDog and Ty 1611 for your input to make this thread searchable..
gkrcr882
SyTyless......for now!
The ELC system is pretty cool, our Olds has it. People freak when they stand on the back bumper and it suddenly starts raising:rotf:
Jimmy
Banned
:haha: I meant to just write "pull the fuse",but decided to post some inane ramblings instead.
tnsyty
Holy crap, people have this and it still works? My shocks died long ago, teh pump and everything is there, but no shocks for it. Glad to see it working out for others still.
gkrcr882
Yup, our Olds is an '87, and it sill works like new. I would imagine that after a while the shocks would start to leak, or the compressor could fry. I don't even know were to find replacement air shocks.:dunno:
ZavzTy547
Senior Member
Rockauto has replacement rear air shocks for fairly cheap.
Yeah I can't beleive it still works either....
Also, Jimmy I pulled the fuse before and what happens is the shocks will eventually bleed the air out and the truck will of course, start to sag and bottom out. This is why I still want the air pump to work but still keep it at 2 1/2 inch drop height.
turbodog
I'm using hi-jackers in place of the original shocks. My setup was more time than most folks would consider to be worthwhile, but I like having the autoleveling with an override when I want it (up for the track, down for the cruise nite parking lot).
QUICK STORM
B.A.M.F. BMW Tech
i got some low mileage air shocks, if you want them. for a price that is.
