Methuselah
My question is: where can I get the metal clips that keep the fuel injectors compressed into the fuel rail? I ramble below.
I was performing the last step before turning over my first hand-rebuilt engine for the first time, building pressure in the fuel lines, when fuel gushed out around a few of the injectors. When putting the fuel rail on the injectors I was extremely careful, ensuring the clips snapped into place properly. I did, however, reuse the o-rings when replacing the Typhoon rail with the Syclone fuel rail (that is, I simply reused the intake from my Typhoon and switched the fuel rails).
I've bought an injector o-ring and cap kit from Napa, under the assumption that the old o-rings couldnt seal up the fuel rail properly. It was when I was removing the injectors from the fuel rail this last time that one of the metal clips broke.
Anyhow, Ive spent hours on issues with the fuel rail, and would like to turn the engine in the Syclone over as soon as possible. Thanks for any suggestions.
________
MERCEDES-BENZ W187
________
MERCEDES-BENZ W187
