Need some advise, almost at 100k
Rexxenexx
OK so the Ty is almost at 100K. The turbo was hungry years ago and decided to swallow a little piece of plastic. A couple of the impeller blades are bent but it still puts out 14#+ of boost. The trans seems to be slipping at higher RPMs so I think any day now and I'll start losing high to low gears until it free-wheels. The engine shakes like it's got a vac leak and it used to poop out white smoke on cold startup but now it doesn't, which I dunno if that's good or bad. ;) Also on cold startup it hesitates to go when first pushing the gas. It's like "wanna go...oop hangon...uh ok lets go!...ummm hang on a sec...OK lets go...err wait a sec... OK fine lets go!" then it's normal.
If I just fix the trans I know I'll be good to go again, but I can't help to think getting someone like Race Proven Motors to pull the engine and trans and go through both and upgrade the turbo to 20G (I have a Hughes 3000 Stall Lockup TC) that I'll be better off. I have only $2,000 to spend. What do you guys think?
syclone rider
Re: Need some advise, almost at 100k
Id say build the trans and buy a vac kit from SYO and drive it unless you want to open a can of worms.
ZavzTy547
Senior Member
The wanna go...oop hangon...uh ok lets go!...ummm hang on a sec...OK lets go...err wait a sec... OK fine lets go!" then it's normal could be a faulty fuel pump or bad sensor. Do you have Datamaster?
syclone rider
Now that i think about it i had to change my stock pump at 100k too.Is there a check engine light on?
Rexxenexx
It doesn't throw any codes on the scanner-Autoxray. I do have a Datamaster but it doesn't work on either of my Ty's so I think the cables a POS or something. I have to look into a new USB only one. Also it might have got fried since the ALDL in the Ty -in question- has a short or something. If you try to do the keyfob reset the jumper gets hot and burns. I'm gonna look into that ASAP by removing the drivers seat and following the remote unlock wire. Dave P and I were on it like a year ago but as usual I got ADD or something and put the whole car on hold. Sometime in the mid 90's the car was in service at Culver City Cadillac and their solution to some problem was to jump at the relay under the dash so the driver can unlock both driver and passenger doors with one push. So I have to somehow undo that.
The whole fuel sending unit was replaced with an OEM piece -FSU w/ pump already attached- the last time I had the trans rebuilt which wasn't too long ago. What sensor you think I should look into?
