need some air to air help
black cat
getting ready to switch to a front mount, just want to know what size IC fits well ,is it better to put the pipes down under the rad support. don,t want cut the truck if possible .i,m hoping to fit one good for around 350 400 hp . battery has been moved electric fan going in and ac is being removed any info or pics would be much appreciated thks i found one on ebay that i thought might be right http://cgi.ebay.com/CXRacing-INTERC...r_Truck_Parts_Accessories&hash=item5addab091f
wildphil
I Love My Ty's
Re: need some air to air help
You will probably be able to find a intercooler rated at the hp levels you are looking for. The only way I can think of would be a intercooler with the intake and exit openings on the bottom. You can run the pipes behind the bumper.
I really didn't want to cut my core support either. I went to the pull-a-part and pulled the core support from a s10 blazer. Put it in place of the original support. That way I could put a pretty large intercooler on and cut the support were needed. And if I ever wanted to I could put the original back on.
T-Bone
T304 piping and silicon connectors/elbows are fine from ebay but you better proceed with caution using IC sold on ebay. Remember, you get what you pay for and when those cheap IC begin to flake internally, the debris will get sucked into your turbocharger impeller and cost major bucks in repair to it and your engine. Save the money and headaches and get a quality IC from the get-go.
wildphil
I Love My Ty's
I think that intercooler could be made to work. If I remember correctly there is 23" between the places the bumper bolts on the frame. May have to mod the inlet and exit so they angle in towards each other. You would have to measure to be sure.
black cat
yeh got the same advise from a bud. do u think the one on ebay is the right size and shape or is still too physically big ,thks just saw post below
wildphil
I Love My Ty's
It may fit without having to mod. It would be best to take the grill off and measure. The core should fit fine. The only thing I am not sure about is the openings on the bottom. It is going to be close running the tubing down. It may work as is. But if need be you could get someone that can weld aluminum to adjust the openings for you.
I bought my intercooler from the same people. I haven't had a chance to use it yet. I have to finish the tubing Friday. But it sure looks great.
skipztt
boost
i know a few guys that have 8sec mustangs with those ebay intercoolers.
just sayin...
black cat
wildphil thats plenty big. i did one like that acouple of years ago on an s 10 but i had to cut the rad support also. it doesn,t hurt anything. but i,m gona try and put one in without cutting. may need a trim here and there
black cat
one more ?. alum pipe or ss. i,ve done quite a few with ss cause its easy to mock up and tack with the mig. the alum is lighter but i find it more time consuming never mention the hydro with a tig
jpalmer
Aluminum tubing off ebay is usually cheap and bends when you clamp it "to" tight. I don't believe the ebay intercoolers are all that bad, just the tubing is a little cheap. You can use it, but take care of how tight you make the clamps, also, buy good clamps, the kind with the bolts, not hose clamps. If you don't make the clamps tight enough, you'll blow off a hose, so either bead roll the ends, or weld on the end for some bite. I know MANY people running ebay cores with no problems, turboxs is popular with my crowd.
wildphil
I Love My Ty's
I think the intercooler you are looking at would be a good choice. It could be made to work without cutting the support. Should look great.
I used aluminum it worked well. I did find out you have to be kinda careful when working with the aluminum tubing. If you are able to weld the stainless that would save you some cash.
