Need some experienced eyes (DM)
SCWolverine
Got DM hooked up and running a few months ago (ugly homemade cable, but it works), and recently got around to actually loging a couple of runs. I've been doing a lot of reading, but would still like to get an educated opinion or two, any takers? TIA
93ty475
Re: Need some experienced eyes (DM)
the only obvious thing i can see is that you're out of injector....your injector duty cycle is hitting 100% at 11-12 psi of boost and you're running up to 15.5 psi...in other words, your injectors are maxing out ....it might be time to look into some 50 lb. injectors and a 50 lb. chip....looks pretty good other than that.....also didn't see any egr activity...are you running a custom chip with the egr disabled? and your intake air temp is kinda high...
SCWolverine
Thanks for confirming my thoughts, my current shopping list is as follows:
50# injectors
3 Bar MAP
50# Ultimate? - I'd like to be able to burn my own one day (or go live), so this might be a step in the wrong direction (?).
Lower IC - Original cant be flowing much air, even after a couple hours of cleaning and straightening fins, still looks pretty rough.
IC Fans
Anything else I'm missing to get her in shape? (besides tuning)
No EGR (blockoff plate), chip not altered, but no cel (?)
All mods were done by the PO, except a Johnson IC Pump.
What he said. I assume you have some type of manual boost controller, the chip is being maxed out for what a 2 bar can register. Despite being maxed out fuel injectors, you O2 Mv don't look at that bad (meaning its not going too lean)
SCWolverine
No MBC, just the wastegate on the PTE60 (need to back it off a bit until I can deliver more fuel?) Thanks for your time guys, I'm sure I'll need more input along the way.
