nello
http://www.mediafire.com/?3ywj0m0kplt warmin up
http://www.mediafire.com/?3c0jz22zm1z WOT
http://www.mediafire.com/?74yl3mwzvdd Cruzin
http://www.mediafire.com/?cycd07hpr12 Idle
Whats up w/ my SY? Shouldn't it be like WAAAAY faster?
When I first got this truck it ran like doo doo...now that I've replaced practically everything, outside the engine, it runs much better but I expected more
New:
Injectors
plugs- gapped .25 (.35 sucked)
8.5 wires w/protective sleaves
cap
rotor
MSD coil
IC hoses (no more metal)
IC scoop
IC pump w/ manual switch
Sil. Vac lines
boost silonoid
AFR
Fuel pressure guage- have pres. set between 32-35 psi
running 95 octane fuel
k&n cone filter on factory tube
alum. turbo to intercooler pipe
TPS sensor
Serpentine belt
K&n breather
Non-engine mods:
TCI deep trans pan
Beltech rear sway
rear dropped 2''
stripped and re-cleared fac. wheels
tires
guage pod: oil press, boost, water temp
I wanted to mention everything since sometimes the smallest changes can create a huge problem...where do I go from here?
Thanks,
Brian
New:
Injectors
cap
rotor
MSD coil
IC scoop
Sil. Vac lines
boost silonoid
AFR
TPS sensor
Serpentine belt
K&n breather
Non-engine mods:
TCI deep trans pan
Beltech rear sway
rear dropped 2''
tires
Thanks,
Brian
