Re: need some measurements,please
singledownloop said:
1.) Is there a resource,maybe here, that i could could dimensions on drivetrain parts?
If you guys can help or point me in the right direction these are the numbers i could really use.
2.) I need the total width of the front differential from the surfaces the halfshafts bolt on one side to the other,
3.) and the length of the halfshafts.
4.) Is the propshaft at an angle from the differential to the transfercase?
I've found the solution to set the front end in my rambler up to go awd.I plan to either have fabricated spindles made that bolt to my mustang II suspension currently in the car that would take the front halfshafts,or have a-arms fabricated from my current crossmember to take the syty uprights.Once this is sorted i will work from there back.
5.) Can anyone tell me if the front differential is directly behind the center of the spindles when mounted on the a-arms or is it slightly forward,or rearward?
Thank you for any help.It's because of the info on this board i abandoned my initial plan of narrowing a stock frame for this project.I will update with pics as this project moves forward if there's any interest.
I'll take a stab at some of this. I broke it up into individual questions so that I can think through my answers a bit.
1.) Don't know of any resource (ie website) with this info on it. But somebody who's got a truck apart might take some measurements for you.
2.) I'd help you with that, but I've got the later model stuff where there isn't a flange on the diff and the halfshafts plug in. So, I can't give you a flange to flange dimension (and mine isn't together anyway, its sitting in my dad's garage). Ultimately, you're going to need a front diff, so you might see about scoring one from a salvage yard (preferably in a ratio you can use). You don't need Sy or Ty pieces. Any 4wd S10 will have almost the exact same axle (but has a 2 piece passenger's side axle with a disconnect feature). If you want a solid pass axle, buy an axle from a Bravada. Be warned that 1st gen S10 and 2nd gen S10 parts are slightly different (no flanges (at least on certain years), but have a drain plug, something that is missing from the 1st gen parts)
3.) Check out your local parts stores. I'd bet they can find one / order you one and you can measure to your hearts content. I wouldn't put junkyard halfshafts in, so don't bother with trying to source them there (my opinion).
4.) This is something you've got control over. It really depends upon your setup. Ultimately, you need to either:
A.) Have the front differential pointed exactly the same as the transfer case. So, if the tcase is pointed tail down at 2 degrees, your front diff should be tail down at 2 degrees (and your rear diff should be the same, front up @ 2 degrees). The ends of a driveshaft have to be parallel for a universal joint to make constant velocity (this is why we don't use u-joints in FWD and on road 4wd / Awd applications).
B.) Install some form of CV joint in the front driveshaft. At that point, you have some latitude over what your pinion angle needs to be.
5.) Don't know the answer as to where it is, however, with CV joints on the inboard and outboard ends, you have some freedom to move it around a bit. Ultimately, the CV joints should be in line with the suspension pivot points (ie the outboard CV should be directly in line with the upper and lower ball joints, and the inboard CV should be in between the upper and lower control arm mounts). However, I think the CV shafts have some amount of axial extension (you should check on that) which would allow you to be out of position by some amount and not mess stuff up. You've also got some flexibility up and down, because of the same features (CV's on both ends and axial extension / compression).
Another thought for you. What gear ratios are you going to run? The 7.25" IFS setup has pretty limited choices (3.08, 3.42, 3.73, 4.10, and 4.56 (I think)). If you're planning on running the BW 4472 tcase (like the Sy's, Ty's, 1st Gen Bravadas and AWD Astros ran) you need to have the effective gear ratio be the same front to rear (gear ratio with compensation for tire radius effects). SO, that means either running the same gears and the same size tires front to back OR running different gears and different tire diameters to get the same effective ratio. Example would be running 3.42's up front with a short tire and 3.73's in the rear with a taller tire, but the math has to work out. Some of the other available tcases might be more forgiving (like the Zexel based tcase in the TrailBlazer SS) but others like the NV149 that's in the Silverado SS won't like it either. And a "On Demand" box (like the NV136 or NV246) will need the ratios to be the same (or something will either spin or break).
One last thought for you, and then I've got to run. I remember seeing a vendor (I believe it was ATS (American Touring Specialties) has a set of forged aluminum C5 spindle (actually knuckle). I mention this because the C5 spindle bearing assembly bolts in place, just like the S10 spindle bearing assembly. Would be worth checking to see whether the bolt patterns are the same or not.
http://www.t56kit.com/FAQ/ Might be a nice solution to having custom spindles made (or maybe not). Don't know if that link will help any, but, what the heck...
Lastly, what Rambler are you building? I grew up as an AMC guy. Dad still has the '68 Javelin he bought new (and I had for a couple years before I decided it was time to give it back before it got hurt). Often its tough to find parts for those cars, especially the little stuff, like trim and window seals (its out there, you just got to know where to look).
'JustDreamin'
