Need stock tune, did search....
Inferno
If anyone can help asap, I wold be super thankful, I am on side of road, truck won't run above idle, currently 3 bar with code 59..... If I hit the map (literally) she runs till I hit a bump, connections look good, I have my stock 2 bar map, but need the code to enter into autoprom.... I have a new lappy with me and cables, gonna download tunerpro to it now..
Inferno
Re: Need stock tune, did search....
Thanks bud, though the file states it is to large to load, I did find a few random files out there, none that say they are 2bar stock tune. code58... but I got to idle, and again after about 15 minutes of driving.... same symptoms.... bucks hard on accel, CEL, and yet idles no problem... thinking my issue maynot be map.... any other ideas.... I gonna keep searching
MRKING
New Parts for Old Trucks
To at least get you rolling along , put the 2bar and stock chip back in until you can make or find a custom fitted bin .
Inferno
right !?! I forgot the stock chip stay in the ECU, good call.....
anyone remember why the yellow wire is cut and going to something else ?!? is that a code59 thing, or am I loosing my nuts ?
MRKING
I am unfamiliar with the autoprom but doesnt it plug into the ecm via a g1 adapter board like my ostrich does ?
Edit : from the pic on moates site , it connects through the same means . Your truck will not run properly without the stock prom plugged into the g1 adapter board .
Inferno
Made it home, thanks to all who offered some help..... still confused as to what was causing that though.....
