Need Sunroof Help BAD!
TYTILIDIE
METH HEAD
Our sunroof in the wife's TY doesn't work. I have removed the motor and gear box but am clueless on what to do with it. How do you identify the sunroof? How do you find parts for them? I have asked around town a bit with 0 results.
NJ93TY
Re: Need Sunroof Help BAD!
What brand is it? Most aftermarket places that install sunroofs/moon roofs can get parts for them.
NJ93TY
I think it is a SKYLITE?
That sound about right, they were big in the 90"s from what I remember. I would
Contact a local sunroof installer and ask them. If the place you call can't help they may know someone who can. HTH
Also mike did you check the switch or try to jump the motor to see if it works. I know on Stephs car the roof leaked onto the motor and would briefly short it out an it stopped working. Once the leak
Was fixed the sunroof has worked great.
TYTILIDIE
METH HEAD
Actually, I pulled the motor and gear box and it seems like the motor gets stuck when its in the gear box.
ed hess
race or get outta the way
Skylite I beleive went out of business a long time ago.
Try this. lube the cables with white grease.
Take the motor apart, clean everything, relube the bearings with white grease.
Reinstall and test.
With the motor out you should be able to slide the panel back and forth a bit allowing you to lube the cables. 30 years doing sunroofs you learn a couple things.
After moving the panel without the motor installed you MUST put the panel in its most rearward open positing to get the cables in synch. if you dont bad things happen. ie unequal load on the drive rails and shit breaks.
mikew
I use Johns Sunroof here in Denver, he has always been able to track down parts, or rebuild what is there.
