Need tunerpro ADL file
I am playing with some things and want to get a file from someone else that is using tunerpro.
adl file of a run, etc would be very helpful. If this works out like I think it will, will make tuning 10x easier for everybody.
jeff@jsmanufacturing.com
sytyguy
Moderated User
Re: Need tunerpro ADL file
Map autotuning (like FAST)? Crosses fingers........
I'll see what I have Jeff.
Hood
ashman
"Map autotuning (like FAST)? Crosses fingers........"
slight OT, but has anyone developed/modified a "off-line" autotuning program to work with $58 code, similar to the AFRTuner, VEmaster, VEFixer, SmoothVE programs, the 3rdgen guys use?
sytyguy
Moderated User
Well.....not sure about outside support (haven't done my homework on that), but FAST has the ability to "autotune" in a sense. IIRC, you make a record of a pass and it will adjust the VE maps (maybe spark, etc....) to "perfect" the tune related to that pass. Obviously, outside factors affect this, so don't expect an onboard KITT Syclone, but it's a vast improvement over manual adjustments in Tunercat, Promgrammer, etc....
This was what I was insinuating above (that and the "bubble").
Hood
The autotune fast does is more of a closed loop via wideband feedback.
That topic has been started at the thirdgen.org board under diy prom section. A guy did some code change to allow for a wb o2 table and the ecm to correct real time for it. The big issue though is if the data the ecm gets accurate for that instant. There is delay in the wb feedback so it has it's limitations.
The ones VEmaster, etc take a run, look at BLM or O2 reading and adjust your tables for you. Megasquirt has a software to do this also.
That can work great for getting the rough information in. I am not aware of a version for our ecm's.
In terms of bubble, it has been mentioned in future editions of tunerpro it would be there. Lets just see when it happens. When it does I suspect the other softwares will have some catchup to do if they don't already. :)
ashman
what does "bubble" mean. a visual representation of the current cell/table?
canadian
sy in progress
in the fast system with the truck running you can load the table you want to watch (say spark advance) and there will be a little "bubble" on the screen over the location of the cell(s) that correspond to the values on the x and y axis.
skwayb
NWSTP
I asked Mark if I could let the cat out of the bag on the next version of TunerPro that Jeff and I have been playing with. He said go for it. This version (v 4.01) should be out in a couple of weeks. It doesn't fix our connection issue yet with our ecm but that will becoming. Any way on with the show... The next version of Tuner Pro RT will show you exactly where you are at in any table as long as you link the correct ALDL item(s) to the table. Here a re a couple of shots of it in action.
These images have the Base VE -vs- RMP & MAP, Base Boost Multiplier (in kPa and in PSI) and the Spark Advace vs Rpm Vs Map tables linked and showing up in Real Time where you are at in each table.
