I was checking my tps% vs. accelerator pedal movement(have to floor it to hard) and apparently my TV cable was a little tight, holding it up. Except I noticed this while turning the thrpttle arm by hand, and before I realized it was the TV cable I heard a snap from the adjuster area and gained some slack in the cable, but it didn't break. Now after readjustment it doesn't ratchet with the throttle like the manual says it should. Did I break something in the adjuster?The cable has an end to it if I pull it, and the noise was clearly from the throttle area, so I figure it's not in the trans. from being pulled to hard. Also on test drive the shifts are real soft and only shifts to 4th w/over 1/4 throttle.I'm going back out to the garage now- got Friday night plans and want to drive this.
On a side note-from the pedal w/datamaster When TPS is at 100% the voltage is 3.69, but push the pedal more and it stays at 100% but the voltage goes up to 4.27. Which is the real WOT?
Jeremy
Jeremy
