need ty shock recomendation for 2" drop
Syclone#2960
What ever it takes!!
I installed 2" lowering blocks in my ty & I find myself constantly bottoming out in the rear when I drive on bumpy roads.
Any suggestions? I'm running fiberglass leafs & QA1 in the front.
BoostedSUV
Re: need ty shock recomendation for 2" drop
Mine is dropped 2" with beltech leafs and billstein shocks and it doesn't bottom out. When I had 2" blocks it bottomed out all the time. The problem is the blocks move the axel forward and you lose clearence in the arch in the frame. Just my 2 cents
Syclone#2960
Im running the custom blocks made by scout78 that center the wheels. Did the beltechs center the wheels?
BoostedSUV
Beltech leafs do center the wheels but if you're running scout's block that's not your issue. What shocks are running now?
dcracer
belltechs are good and firm mine don't bottom out,
maybe to firm for some roads.
Syclone#2960
Let me a take a pic of the shocks...they are brand new with coils around them. I was hoping it would fix the problem.
BowTy
Not sure if that is "the" issue, had a car with worn out front shocks, ran Sensatracs and was not any better :lol:, still drove like an old float-boat. Swapped to KYB on that car then it was firm and properly controlled as I remember the car when it was stock. Might be something too about it not being in its range when the suspension is lowered. On my Ty I have always ran the Bilsteins, never a problem with bottoming out, but I also trimmed the rubber bump-stop to be more progressive, not whack the thing short so it hammers hard when it comes into contact, but instead trimmed it so the point was not as wide, from top/point to bottom/base, if you get my meaning.
0966Sy
Code what?
I got the QA1 coilover's, you can fly over anything and bend wheels before you bottom out. Im running them with belltech leafs and 1" blocks
Throws
I say the Monroe spring-assist SensaTracs.... pn: 58523.
-P
TYTILIDIE
METH HEAD
I use beltech drop leafs with KYB Monomax. Mine bottoms out when I hit something severe but really its not very often. My goal though, is to have coil overs back there.
