New 52mm Throttle body
Black Knight
I Glow Therefore I am
Re: New 52mm Throttle body
There was the guy who would rebuild them and could punch them out to 52mm. I'll check for his info when I get home.
Ty 1885
Thanks Black Night, but i had my rebuild by a guy from ebay ( the one everyone talked about). Only drove it 2,000 miles and its leaking air.
He made it 52mm, air foil, and new shaft sleeves, but left badly worn shafts. Worn shafts killed the sleeves, and they are moving around causing air to leak.
I want brand new one.
warmpancakes
mike lee had the last of the BBK you can make a camaro one work by swapping the "connector" on the end the thing the cabels connect too
Black Knight
Sounds like Ken has your only bet then, because the only new ones I'm aware of are the 58mm.
Black Knight
Stock is 48mm, correct?
Matt, mjb_machine@yahoo.com rebuilds them and makes them 52mm. That's what Ty1885 and I have, but he's not happy with it so he's looking for a brand new 52mm (I'm not aware of anyone who makes one).
I was then stating that the only new option I was aware of is the 58mm, not that anyone wants one.
HTH
Foot Performance
HTH
The 58mm I have seems to run and idle fine I did have to readjust the TV cable. I am running a waller upgrades stock turbo.
Just curious why no one wants one?
Black Knight
Your reading it out of context, I didn't mean no one ever would want one, just that no one in relation to what we're talking about wants one.
I know what you think I meant and I can't figure out how to word it differently :D
Foot Performance
:lol: Ok I just thought there were un said problems with the 58mm I feel better now
BTW sorry for the high jack
nallj92
summit has them in 52 and 58, and also professional products has them in both, polished and satin. they are camaro/tpi/lt1 style but you just need to add your end linkage to it, have to drill out the two mounts and bolt on the syty end.
nallj92
tpi is the one you would want to get, the TPS mount is the difference between tpi and lt1. sytys are same as tpi, plus the added linkage
jwaller
Evil Genius/SyTy Guru
remember that the TV cable rate lever is syty specific. so you would need to remove your old one and install it on the new TB.
