New Alternator
akwilks
Mr. Keith
I bought a new alternator...160a, now I hear a whine in my stereo...driving me nuts...what can I do....do I have to buy a capacitor?
wantingasy
Re: New Alternator
THAT'S WHAT THAT IS!!!!!!!! I also got a new alternator not too long ago and my speakers make a humming noise when the radio is on. But when it's off, no humming!!! I was about to buy a new stereo head unit!!!
Black Knight
I Glow Therefore I am
Re: New Alternator
Bad ground... maybe??? Im not the stereo guy, but I thought when you got a humming noise it was either from running your speaker wires on the same side of the vehical as your power cable or a bad ground. Also I thought capacitors were just for storing power for when the electrical system couldn't supply enough?? Again not a stereo guy just tossing around ideas.
wantingasy
Re: New Alternator
I thought it was a bad connection to my head unit so I pulled it out and double checked all the wires and they're fine. I don't think it's a bad/weak ground because I had a professional shop install it (but you never know going that route). Will check that out. I don't know what else it could be. Most likely a capacitor will not fix it, as that's mainly just for stereo systems on its own. I'm stumped as to what it could be. Best thing I can think of right now is to check the ground.
Houseofperformance
switchhappy!!!
Re: New Alternator
you need a device to suppress radio interference - sorry, i have no clue how it´s called in english?? some kind of screen/shield in the cable line.
Captain Morgan
Moderated User
Re: New Alternator
the best solution is to not use the factory radio harness.
I ran a new ground from the head unit to the frame, a new fused 12V+ constant to the battery and a new 12V+ constant that goes to a relay which is triggered by the original radio ignition wire.
wantingasy
Re: New Alternator
Uhhhhh.....is there an easier way? Can I just run a ground to the body, say behind the dash there?
H-TOWN-TYPHOON
You're killin' me, Smalls
Re: New Alternator
It's called a ground loop isolator. I think you can even buy the schosche brand at wal-mart these days. Back in the 90's when I worked in car audio we charged ~50 bucks per, now I'm pretty sure they are around 10, so it wouldn't hurt to give it a shot.
Captain Morgan
Moderated User
Re: New Alternator
who says its the ground causing the problem? a good ground might only be part of the problem. Heck even doing this, my ground goes directly to the chassis. Going to the body still leaves the chance of interference I think. My head unit, amps, caps, ect. all go to a good chassis ground or the battery itself.
Here, I made this earlier today but didnt have time to post it before I went out to dinner....
The only thing I may have left out is a fuse in the 12V+ line going from the battery to the relay and I actually have the relay going to chassis ground, not the battery like the picture shows, I realized that just now, but Ill probably fix that in a few mins ;)
Ive ran isolators and noise capacitors before, they are just bandaids IMO and none of them work as well as this has, but thats just my :2cents:
akwilks
Mr. Keith
Re: New Alternator
A capacitor blocks dc and passes ac. Supposedly you can keep the hum from the alternator, a dc source and shunt it to the capacitor before it goes to the amplifier.....That was my understanding
