New battery relocation
Ty 1885
Just made my own battery relocation location!
It took me 1 hour and cost $5
NO. 1) remove your battery, and battery tray.
2) remove pass tire, and wheel well.
3) cut off the part of the tray that bolts to the rad support (make it even with the rest)
4) lower the tray from orig position till it stops about 4 inches, just above the bar that bolt to the frame.
5) drill two holes thru the tray and the part it sits on, get ss bolts/nuts and bolt them down, do the same for the side.
6) after removing the wheel well, you should have a 1 inch by 7 inch braket with two holes, bent it into "L" shape, place it under the tray and bolt it to where the brace bolts to the frame, and then drill a hole to attach it to the tray.
7) Now you need to cut front part of the wheel well even with the bottom of the tray. You can attach it to the tray or just leave it like that.
8) you need to add a small piece of neg cable. about $5.
Check out my pics on my sig.
Norm
Re: New battery relocation
sig link doesn't work, but I think it's one of those things pics would be great to see, it's not always about how much it costs, but how well it works.
turbodig
Same place the ATR battery relocate used. They even had a panel that went in your fenderwell that you could pop a bolt out, and get access to the battery via the wheel well.
SY2932
Administrator
Yep:
Ty 1885
That is NOT the same place that i made mine! If you look carefully, you can see that my setup sits higher, makes easy to access from the top, Just like factory.
