so i have a new fully built motor with vortecs cam ect. i have put a few hundred miles on it at 20 psi or so no issues no knock. i swapped out my msd box for a new 6al2. i drove it to work this am and pulled mint. all of a sudden the next time i got into it, it started breaking up bad. so i turned the boost down and same issue. i took the msd box off and ran the coil off the factory wires and it seemed to run ok. but when i turned to boost back up to 20 or so psi it breaks up again.....not as bad but still is. are the factory ignition systems with more power and methanol good enough without an ignition amplifier of some sort? its a brand new delco coil as well. thanks
