NEW combo almost done!!!
SYCLONE#1531
'MOFOFAST
Im finally almost done with my new set up for this new racing season! Im pretty much finished up top with the new intake from RPM. (This would have to be a major improvent over the factory intake at 26lbs!!!!) Pulled the transmission today and also recieved my Vigilante 3400 triple disc conv:D. A friend of mine is building the transmission next week.. Should be rolling again next weekend!! Maybe I will get a 10.99 out of it at Silver dollar race way next month! Ive got my fingers crossed!!:lol:
SYCLONE#1531
'MOFOFAST
Re: NEW combo almost done!!!
11.70 with a 3lb launch. had a bad convertor... Im hoping a 10lb launch with the Vigilante locked will get me where I need to be!!
Couple quick questions. Is this Mike's entire cold air setup? Also is that Mike's AC delete kit? On the AC delete which I bought from Mike the tensioner was going over center. I repositioned the tensioner and used a shorter belt. Also got it more out of the way and closer to the WP. I'll attach a pic of my decidedly crude but fully functional solution. :rotf:
Good luck with those times. :tup:
SYCLONE#1531
'MOFOFAST
I made the cold air setup (3 inch mandrel aluminum 90 with a cobra elbow). Had to cut the inner front fender as seen in pic.. Yes this is Mikes ac delete kit. also I would like to see a picture of yours!!:D
Big Mike
You might want to run another pcv to the intake pipe before the turbo inlet. (off the factory u pipe not shown in your pics that comes off the valve cover).
Tensioner mod. All I did was rotate the tensioner on the water pump bolt toward the water pump and use a 2bit bracket off Mike's existing support to keep it there. Didn't even grind the corners off as you see but did put a little S bend it it to allow for the thikness of the bracket.
Mike's design is on the right track just, for whatever reason, on my install, the tensioner would go over-center. Anyhow one day I'll reconfigure Mike's bracket so it fits correctly.
BTW Belt #'s are:
835K6
6PK2120
I had to make the bracket to fit the belt. I think this is the next shorter from Mike's belt.
Long post hope it explains things.
Overall eng comp pic:
