0966Sy
Code what?
Just started my Syclone up for the first time since August. (Note: Has less then 1/4 of a tank of old gas.) Ya it took me this long to save all the money, and i was bored so i started to tare apart things early. Following mods and syptoms below: ( appreciate the help
PTE-52 kit
50# Delphi's
50# Ultimate
RPM A2A
Walboro 255
accufab AFPR
NGK UR6's
Taylor wires
Conrad cap/rotor
Griffen rad, with dual ramcharger fans
165 amp alternator
2800 stall
optima red top
Now the symtoms : ( or what i've checked
It starts right up after a jump
checked FP and it's at 43
when it starts it idles at 1500-1600rpm for several seconds and then goes down to 900-800rpm and idles smooth.
the truck wont idle for more than 5 min without bogging and stalling out.
no smoke out the exuast.
no visable injector leaks
only pulled one plug and it looked fine
boost guage reads 19-20vac at idle
cab lights dim as motor die's
die's with fans on or off
voltage guage in dash reads 10-14 but goes down when motor bogs
Im thinking water in the gas, but i cant visually see any in the sample i took from the fuel filter. Water should be at the bottom if any.
Thanks for the help
Erik
PTE-52 kit
50# Delphi's
50# Ultimate
RPM A2A
Walboro 255
accufab AFPR
NGK UR6's
Taylor wires
Conrad cap/rotor
165 amp alternator
2800 stall
optima red top
Thanks for the help
Erik
