New Fuel Lines?
I've been searching High and Low, Including LMC Truck for new fuel lines for the typhoon...
Searched blazer, jimmy, typhoon, etc. nothing.... anyone know where I can get new fuel lines? Preferrably ones that are better than stock...ive seen stainless braided kits but they are only for certain points of the line...not the hard lines near the left side rear shock... right on top...
Is there a good way to repair these if they cant be purchased new?
Foot Performance
Re: New Fuel Lines?
I think maybe turbotime has one from the tank forward( I thought) RPM has them from the t-case fitting. if that helps
Re: New Fuel Lines?
I sent my originals to Inline Tube and they duplicated them in hard stainless. I don't know if they saved the specs.
Loeryder
Re: New Fuel Lines?
Call LMC and ask them.
They used to be in the catalog but all I see now is stainless transmission lines.
1.800.LMC.TRUCK
BigBadSmoosh
Re: New Fuel Lines?
inline tube has them.. at least that is where i'm going to order them from for the syclone. After all they are pretty much the same as stock s-series lines.
Syclone#892
Re: New Fuel Lines?
Be careful with braided stainless lines, here are a couple things you may have not know about them since I know I didnt.
Braided lines "sweats" basically it leaks a very small amount, does not cause a running problem but it is very annoying having a constant gas smell.
It is not a lifetime replacement, from what I heard when I replaced mine it has a 10yr lifespan. Well my truck sat for 4 yrs after i installed mine, finally got it running a couple months ago and the return fuel line burst in 2 spots had to replace all 15 ft of it. Defiantly scared about the others breaking and am looking into replacements.
Cutting and installing fittings is a pain, its not a huge deal butt make sure you have something good to cut hose so you are not constantly recutting it to get a good cut and end up making your hose short.
I have heard that regular pushlok hose is cheaper and has a better life span, I will be going to this or bigger hard line.
Here is a reall good thread about braided line.
http://www.pro-touring.com/forum/showthread.php?t=44184
Good luck
92ty#178
Re: New Fuel Lines?
I called inline tube.And one of the guys told me that they dont have them for the Typhoon. And mine are spliced. Anyone have a donor set to send them?Unless they are the same as a jimmy and they just dont no that maybe?
BigBadSmoosh
Re: New Fuel Lines?
I would assume the lines from the tank to the filter are the same for sy/s10 and blazer/jimmy/ty
The lines from the fuel filter to the motor might be different.
