mrweelr
OK, I've REALLY done everything now to get rid of the KR. Yesterday, I replaced my knock sensor with a new one and cleaned the grounds on the alternator, engine block, and firewall really well. Result - not a fucking bit of difference! I installed a new Borg/Warner cap and rotor while I had the distributor out to install the new oil pressure sending unit and knock sensor (old cap/tor only had 1000 miles on them). I took a Datamaster run yesterday after putting the new knock sensor in and was getting up to 8 degrees of KR :x So today, I took it back apart and loosened the knock sensor up a few turns to be sure it wasn't overtightened. Hooked it back up to Datamaster with the same Chevron 91 octane shit and KR is the same and volts are still dropping to a low of 12.9v at WOT. At idle, my volts are 13.6v which seems OK but at WOT I'd like to get it higher. So I really feel as if I've done everything to get rid of the knock now and can justify putting the SMC alky kit in. Bottom line is the 91 octane crap we have to use in the Bay Area is the problem. I should have the SMC kit within the next few weeks - can't wait!
Here's just some of the stuff I've done to my truck since I bought it with 47K miles in September:
RedLine WaterWetter
RMI25 Cooling System Treatment
Redline Injector Cleaner(2)
GM Top Engine Cleaner
Mobil 1 5W30 Synthetic Oil
Mobil 1 Oil Filter
GM Transmission Filter
Mobil 1 Synthetic ATF
GM Fuel Filter
Magnetic Engine/Trans Plugs
Derale Deep Transmission Pan
Kenne Bell Cold Air Kit
Kenne Bell Red Hots
Kenne Bell FPR @50psi
Kenne Bell TC Lock-Up Switch
ATR Chrome Diff Cover
Bob Berterman IC scoop
Powermaster 140Amp Alternator
ATR High-Flow Converter
ATR SS Exhaust
B&M Transmission Cooler
NGK UR6 Plugs
Borg/Warner Cap and Rotor
HotShot Starter Relay
ATR TB Airfoil
Walbro 255 Fuel Pump
Reroute IC Hoses 3/4"
Jabsco IC Pump (Hotwired)
Koni Adjustable Shocks
Kenne Bell 2" Lowering Blocks
Optima RedTop Battery
Hood Latch Guard
Engine Tie-Down
Disabled EGR
Removed Spare/Jack & Much More
Sony M670 CD Player
Pioneer TS-P462 speakers
Kenwood KFC-415C speakers
Altezza Taillights
Momo Steering Wheel
LoTek 2-Pod 2 1/16"
AutoMeter Boost Gauge
AutoMeter Electric FP Gauge
New MEMCAL #16164174
New Ignition Module
New Oil Pressure Sender
New Knock Sensor
New AC Delco Coil
New Vacuum Hoses
Waiting to be installed:
PST Front Suspension Kit
PST Idler Arm
Moog Torsion Bar Mounts
Moog Pitman Arm
SMC Alky Injection
Baer 13" Brakes
Hamann HM2 18 x 8.5" Wheels
Kumho 255-35-18 tires
What's left:
Ultimate, 3-Bar MAP, 50# injectors
PTE52 Turbo, Wastegate, Downpipe
Electronic Boost Controller
9/11 High-Stall Converter
RedLine WaterWetter
Mobil 1 Oil Filter
GM Fuel Filter
Kenne Bell Red Hots
ATR SS Exhaust
NGK UR6 Plugs
ATR TB Airfoil
Hood Latch Guard
Engine Tie-Down
Disabled EGR
Sony M670 CD Player
Altezza Taillights
Momo Steering Wheel
LoTek 2-Pod 2 1/16"
New Ignition Module
New Knock Sensor
New AC Delco Coil
New Vacuum Hoses
PST Idler Arm
Moog Pitman Arm
SMC Alky Injection
Baer 13" Brakes
What's left:
