New Motor first datamaster run (updated)
bezerk
your O2 Mv seem kinda low to me when you are under boost.
try to get that above 900, and see if knock goes away.
BTW, how full was the tank when you drove it?
can somebody explain me why the taget boost isn''t reached, because KR is appearing, the wastegatesolenoid opens up the wastegate a few procent?
MikeRenz
not stock
ok i found your build on your cardomain listing.
The first thing that i see that you NEED to swap out is your plugs. Switch to NGK TR5 or TR55 plugs. Vortec heads will foul the cr42ts's in about 5-10 minutes or run time.
odium
1BADGMC
What does it mean if boost TGT is always 0? His isn't doing this, but my runs are leaving boost TGT = 0 at all times... It has an ATR Pitbull, if that matters.
MikeRenz
not stock
i'd do something about this before doing a ton of WOT blasts at over 100mph:
Captain Morgan
Moderated User
compared to my truck, his Spark Advance is in the mid-30's where as mine is at 24.3* and his idles about 100-150 RPM too high also. Is this a distributor adjustment?
InvisiBill
http://www.syty.net/phpBB2/viewtopic.php?t=40028
dgoodhue said:
From what I understand, the ATR Pitbul doesn't have feedback for boost control (closed loop), it just opens the wastegate duty cycle for a certain throttle percentage (open loop) Did you adjust the wastegate at all?
FYI the pitbull wastegate table looks like this
TPS % 0 12.5 25 37.5 50 62.5 75 87.5 100
Wastgate 52.0 53.5 56.2 58.2 59.8 64.8 66.0 68.8 75.0
So 74.9 is right on for 100% TPS
The ATR chips don't use a boost target. They simply tell the wastegate to go to a certain percentage.
MikeRenz
not stock
maybe he never zeroed?
Captain Morgan
Moderated User
I was talking to him about it last night, while i was uploading his file. He said it was at 0* with the brown wire off, but I wasnt sure if the cam would change the 0* timing or not....
Just seems weird to me.
MikeRenz
not stock
mine never did that w/ the 412. 422 isn't much different.
I'd double check the stupid cam sprocket to make sure the notch is at the right spot, but a shop assembled this motor for him, so i'd hope that'd be right. This wouldn't affect the timing though, just make it run shitty.
maybe his cap/dist isn't bolted down completely. a cap can easily move itself if its not tightened down.
other than that, i wouldn't know, since i'm not exactly a pro. :lol:
The ECM doesn't read total timing, it only know how it advances or restard the timing. It has no control or ability to know what initial timing other than what is put in as constant inot the programing (in our trucks it is 0, in my corvette it is 6)
In Ted's Datamaster, it appear as though he is getting some false knock as some spark retard appear when he rev'ed the engine.
tbauer03
TRBOBOX
I actually got tr5's in there i will recheck the timing to see if it has moved. Fuel Pressure is at 35#'s should i turn that up to get my o2 mv in the right area.
MikeRenz
not stock
what 50# chip are you using. 35# is too low for base pressure on most 50# programs (ones i've ever heard of anyway)
tbauer03
TRBOBOX
timing was about 1 or 2 degrees after TDC now it is at zero and tight, how i high should i raise my fuel pressure. Jim Sloan gave me the chip i don't know anything about it.
bezerk
put it a 40, and hook up datamaster, see if the O2 went higher.
