typhoon4ever
this sucks. after spending $140 on a 6A,i run the truck with datamaster and the truck is knocking more than before. When i disconnect it and run stock ignition, knock is reduced. I have the original gm coil.
MSD can be hooked up wrong if you dont have the plug in harness. You can hook it up backwards... could cause an issue
That's it! That could be my own problem. I have checked my ignition parts once and twice and some three times. But not ALL three times, I suppose I foolishly thought that my efforts were already enough. Ryan I will owe you one in spring if this is the fix. :smile:check ALL ignition components, 3 times if you have to it is the SYTY curse. We've seen small cracks in plugs cause problems so don't rule anything out when it comes to ignition.
It's later now, any more info on what's going on? Can you email me? I wanted to private mail you but you don't have an email link. Thanks.Ignition help for the SYTY community is on its way, more to come on that later.
On 2002-01-23 18:33, JoeLutz wrote:
Don't the older FWD 3.8s with coil packs get the signal off a crank sensor? If you do away with the distributor, whats going to drive the oil pump? Just curious. I remember seeing some type of aftermarket coil pack conversion that used a kind of dummy distributor that drove the oil pump and had a Hall sender for the engine speed and position. Just was flat on top with no rotor or dist cap.
No cap or rotor to give trouble and usually beter spark and timing control.On 2002-01-29 20:03, typhoonrider wrote:
whats the advantage of a coil pack over the stock distrabutor?
