T66Typhoon said:
Sounds good Brian.. any info on what dist that Accel one is?
I have been planning this as a work week for the truck since the plant is shut down and can get my hands on the parts to do this.... I would be interested in playing with it this week... let me know if you have time to share which dist and I will get an eDist...
Very interesting ... (mad scientist look on my face)
EDIT: Ok so I am very interested... I went to Mr. Gasket's website and found the distributor you are talking about.. so I think...
http://www.mrgasket.com/accelpdf/ACCELfuelinjection.pdf
Check out page 6... I don't see one listed for a V6.. I assume there is one or you have a master plan for working around it... at any rate.. I am trying to play techno catch up here and understand where you are at.
Like I said... plant shut down this week.. I got the truck back together today already.... expected the few things I wanted to do to take longer.
That's the type of distributor you'd need. The 4.3 app is new. Ken (warmpancakes) works for Accel now, and assures us the 4.3 V6 distributor is available. I think he posted the necessary part number in the lounge. I still want to see some more details on it. I'm not sure Ken has run it with the eDist to verify 100% that it will work, but I don't see any problems.
As far as the 3.1 - I believe they couldn't get it working 100% correctly in the syty app, and it may have required some code changes to work. Also that is still a wasted spark.. so the LS1 coils are ahead again.
The MSD system is pretty nice, but expensive. It uses *MSD* coils, not LS1...so the harness is useless. The whole MSD thing uses one of their new modules, and all timing is controlled by it. Nice system for a carb setup, or an older EFI retrofit and so forth, but i don't think it's going to help us.
The rest of the guys need to sweet talk Ken & Nick... talk Ken into getting Nick a distributor, then Nick can mock up a complete harness for LS1 coils & the Accel distributor, so it is plug n play. Then he can either make up those harnesses, or better yet, send it to Casper's and they can duplicate it on demand for any syty owner. Once that is done the difficulty will be just mounting the LS1 coils and setting the distributor up. So then you sweet talk Mike Lee into making up a bracket for the 4.3 for LS1 coils to mount to, or just buy a set of his valve covers and he can mod it for LS1 coils (speaking for mike here, no clue if he'd want such a project).
Ideally, you'd want to be able to use the LS1 plug wires, but that may not be an option for some people (guys with headers etc).
