New owner - help please (coolant temp & knock)
rxsyclone
I got my Sy last night. Before starting it I installed a new battery, an AC oil filter and 6 quarts of Mobil 1 (too much I know). After extensive testing I find that:
1. Coolant temps are too hot for me to be comfortable with. It never approached 260 so far, not even the last section, but it normally sits at almost 3/4 way hot, and increased with heavy driving and the A/C on. What is the normal reading?
2. There is a steady knocking at idle from the throttle body general area. My guess is it's engine knock? I am using 93 octane and pray that after I change the fuel filter the knocking will go away. Truck has just under 30,000 miles and is in good appearance and unknown mechanical condition.
3. The truck smokes from the area of the base of the oil filter neck. My guess is (I hope to God) that I spilled oil as I filled it - I know I spilled up to 1/2 qt. I guess I will find out if it burns up after a couple of days.
Is there something that could cause engine pinging, smoke from engine bay, and hot operating temperatures. Guys please don't freak me out. It is possible that I just need to install a 160 degree thermostat for 100 degree Florida weather and change my fuel filter or something. The truck feels like it's running ok, but it's far from violent fast, maybe very low 14s in the 1/4 mile right now. Please help me with some good advice. Thanks a lot.
Re: New owner - help please (coolant temp & knock)
Do you have a datamaster scan of the truck yet?
My coolant temps stay in between the the lowest and second notch on the temp gauge on the dash. For me, that is about 170*
I would do a full tune up if it hasn't been done from the previous owner in recently.
rxsyclone
No, where can I have that done (or get Datamaster?) We have Tech1 and Tech 2 at work. I am in the process of a tune up, but the overheating/knocking/smoking seem like serious symptoms.
rxsyclone
Does anybody know the part number for or where I can get a 160 degree thermostat?
maty111
If my temp gauge goes past the first tick mark I get scared. discout auto parts carries the 160 deg thermostats. your in florida? what part?
matt
Baythan
SY2TY2SY2TY
Is it a knocking...or a ticking near the throttle body?
Syclones have distinctly loud injector ticks that sounds like dry lifters. You'll get used to it. ;)
QUICK STORM
B.A.M.F. BMW Tech
check to see if your radiator is plugged. after it gets hot put you hand on the radiator fins(with a glove on) and see if you have any abnormal hot or cold spots, then you know your radiator is the problem. get yourself a mechanical gauge, stock gauges seem to be quite inaccurate.
Look at the tmeps with a scan tool, most factory gauage don't read that hot (or accurately).
Is it any chance you had a paper clip on the A & B terminals of the Diag connector. Its sound like the IAC is making nosie. It could be fuel rail tick as well.
Pull the oil fill (driverside) Put your hand over it to feel if its blow out. This is a bad thing if it is.
rxsyclone
Well, I changed the fuel filter and purchased a 160 degree thermostat and gasket from autozone, as well as a Duralast brand cap and rotor. The fuel filter swap did not decrease the ticking sound, although it was dirty and I'm glad I changed it. The smoking is completely gone, it was just my dumb ass spilling Mobil 1 by the filler neck. I don't have the tools righ now for the thermostat, but the temp is usually just a bit over half, unless I am driving hard. It sounds like you guys are running way cooler, so I plan on flushing the radiator. Where is the drain plug? I found the heat exchanger drain, that was easy, but I cannot seem to locate the radiator drain plug. What fluid do you all run in the intercooler? From what I understand, distilled water with water wetter cools best, but antifreeze is needed to lubricate the pump. I also have 2 cases of Royal Purple max atf laying around, and a tranny fluid exchanger at work. My instinct tells me to do it, but few people have commented that synthethic will destroy the tranny. What should I use in the tranny, and the front and rear pumpkins? Also, I am so glad to hear that Sys have extremely loud injectors. Because the truck runs pretty normal and the ticking almost seems normal, except it's so loud. To describe the sound, it is as if the engine is shaking something small inside the throttle body. I used Wynn's combustion chamber cleaner from work (GMC) through the vacuum system just for the hell of it, nothing good or bad happened and I don't plan on using it again any time soon. Sorry for the long post and all the questions, it feels good to have the Sy running better and better, and I am grateful for all the advice. Right now it's in the garage while my third gen twin turbo rx7 with very low miles is sitting outside in the rainstorm. :)
rxsyclone
matt
Homestead
Roland
rxsyclone
Is there an aftermarket radiator that is more efficient, and easy to install? I wonder if I can afford one right now. I usually treat my cars really nice, I would just install a brand new rad instead of flushing the 15 year old one and looking for hot spots, but gas has been killing me and I still haven't sold my RX7. :(
First pull out the thermostat to cool the engine
if you have just run it with out a thermostat until you can get one.
ANY Standard 350 Chevy thermostat will work you can get them at Napa or any autoparts store Even Walmart has them.
High temp will cause Knock and high temp is Bad for the Bearings i found out the hard way
I had to get a New engine because i ran it way too hot one day and when i changed out the oil i had Copper Flakes in it due to Bearing loss and a Very Fast lose of Oil pressure.
rxsyclone
OK, my only main problem now is overheating. I have never allowed the needle to wonder into the last section, but it spent some time at 3/4, and as it is it is a mission to keep it at 1/2 by manipulating traffic to cruise lightly and with the A/C off. I realize these readings are abnormally high. I just came home from autozone buying swiwel adapters and extensions to get the thermostat housing off. I beleive it is not opening at all because the radiator is COLD ALL OVER AFTER HARD DRIVING !! I am shocked that the truck has not completely overheated in this weather without any radiator as it seems. The upper radiator hose seems hot however. I am going to change the thermostat now to the 160 degree unit. Any info on flushing the radiator?
On another topic, were Syclones supposed to have mufflers???? I thought they didn't have any, but mine has 2 that are "Super something" brand and the truck is disappointingly quiet. Please don't tell me the older person who owned this truck installed mufflers to cancel any unwanted noise! The pipe splits into a Y after the cat, and each leg has a big ole muffler! Confused......
Thanks for everything and wish me good luck
SuperTurbo Dynomax's as you described are the factory set up.
rxsyclone
Damn it, I was looking forward to removing them..
Well after the 160 degree thermostat + gasket install the truck still runs 1/2 reading on the stock temp gauge with cruising in 80 degree weather. I still feel like this is too hot. I tested the colant and it seems to offer protection up to 265 degrees according to the cheap auto store gauge. What's next water pump??? You guys are all running 1/4 reading on the stock gauge in hot weather? I need help on this "overheating issue". I just ran a 14.0 @ 97 mph on a G-tech pro with my wife driving in pouring rain. What do you think? Thanks.
I would do a coolant flush. Get any stuff out of there that might be clogging things. After that, I would try a water pump as they aren't to hard to replace.
also make sure your clutch fan is working correctly
rxsyclone
I am willing to replace my water pump and even more willing to flush my coolant. Can anyone tell me HOW TO FLUSH MY COOLANT? Also, what aftermarket brand of water pump is available that is superior to stock? Thank you.
QUICK STORM
B.A.M.F. BMW Tech
you work at GMC right? well if you do, some off the tool guys that should be coming around to your dealership should have a flushing tool or your dealer should have one. it sucks on our radiator cause there is no drain plug, only way is to pull the lower radiator hose. any way back to the flush machine. my work has this awesome machine. it has two tanks, one for old colant and one for new. what you do is you run the truck to operating temp, put the hose on the radiator, turn a couple knobs and it draws the old coolant out with a vacuum/suction action. then once all the coolant is out, turn a couple more knobs and walla, new coolant is drawn into the radiator. hope this helps.
QUICK STORM
B.A.M.F. BMW Tech
oh and do a search for the water pump if you already haven't.
