Ty 1885
Hey, after 3 runs at track (TY was off for 5min) lifters on pass side started to make loud noice once it started. This happed once , i thought maybe it got hot, and a lifter lost its prime.
Yesteday i pulled pass valve cover. One of the rocker studs turned at only 30 pounds with torque whench.( must have over tighted that rocker before)
Because i run roler rockers with ARP metric studs, i had to put ARP washers under the studs in order to have more treads for polylocks. One of the studs pulled some of the treads out of the head. In order to FIX this i had to REMOVE the washers on that stud.
Now i have 4-5 treads to hold the polylock. It should be fine with the single springs, right ???
Thanks..
Thanks..
