Windedv6
Ty n 10s
I revived 93 Ty #0735 from the deep. All that remained was the cab, no frame, no front clip, no drive train, no wheels, etc. I did get the cladding except for the front bumper and bumper support. The passenger front cladding is broken. Considering all that and some rust she looks....well...good.
Since I own a ty that is a v6 AWD, I am planning on doing an Alston 4x2 chassis with a 14 point cage in this one. So that it's still streetable, I am using the a-arm coil-overs instead of the racing strut front suspension and will have a front stabilizer bar and rack-n-pinion steering. This chassis should handle well on the street. The rear is a competition fab-9 housing with a Strange center section and Strange 35 spline axles with a competition four link setup. Wilwood brakes all around.
Interior will sustain the stock dash with a modified gauge setup, stock interior panels and carpet in the front. Modified interior panels and mini-tubbed in the rear. Seats will be an after-market racing bucket.
The trans will be a built turbo 400 with a trans break.
Here is the mystery piece. I am on the fence with regard to the motor. I want 1,000 to 1,200 hp at the crank and I will not build an odd fire. I have a complete oddfire from Katech that I was going to rebuild and use some of the components, but have been talked out of it by several previous oddfire owners. The guys at Wheel to Wheel raced a couple of odd-fires for several years, but had the horror stories about how every bolt came loose all the time. Even the water pump bolts would come loose and leak. An oddfire is just not a good street/strip motor.
To get a v6 even-fire to 1,000 hp plus is like asking a v8 to do 1,300hp ...and do it with an offset crank. I truly believe at 1,000 hp a billet even-fire is asking for about the same problems as 600 hp with stock crank....it may hold...it may not hold. The claim is that a billet even-fire is only about 20-25% stronger that a stock even-fire crank.
So the question is...do I push an even-fire v6 its limits and maybe beyond or go with a twin turbo v8? I am looking at a 408ci sbc ...dart block with 18* heads, Callie dragon slayer crank and lunati rods. What is interesting is that everything looks, feels and smells like our v6 but has the two extra cylinders. Of course it is much stronger and about 1/3 less price.
Innovative Turbo makes a cast twin turbo exhaust manifold that bolts on the 18* v8 heads and is good to 1,200 hp. it's a cool piece that doesn't take up a lot of real estate under the hood like headers do. The Banks twin turbo v8 setup uses these same exhaust manifolds.
My goal with this Ty is to be very streetable for the weekend and run eights at the track. Weight should come in around 2,800 or less.
The project is moving along nicely. The cab as been gone through and any rust has been cut out and new metal welded in. The front motor mounts were nasty and were replaced with custom made ones. The chassis will be here next week and the rear end, the following week. The Alston guys are great to work with.
Open for ideas and opinions.
John
John
