New Setup, Working out bugs, Could use some help.
Posted this at 59.org but like any SyTy-er I am anxious to know what I need to do so the truck runs right.
I can e-mail the TP logs and the BIN.
__________________________________________________________________________
Finally got my Typhoon back together. It is a used motor with 114k on it as a hold over till I get the funds to finish a built motor. The truck almost complete, save for the intercooler pump and plumbing.
The problem I am having are that it is running very rich. I tried several 60# bins from code59.org and syty.net and they all behave about the same. It was running about 9:1 to 10:1. I adjusted the F28 table to try to bring the AFR up at idle but the AFR started to swing between 11:1 and 14:1. When moving, AFR drops to a solid 9.0:1 which is the richest my WB will read. The idle RPM was also started oscillating up and down. I probably have a mechanical issue but any help on where to look and what to adjust in the tune would be greatly appreciated.
Specs
Block: Stop
Cam: Stock
Injectors: 63#
Intake: Lightly Ported upper and lower
Turbo: 60-1
Wastgate: External controlled by spring only for now. Have EBC for later.
TB: Stock
Map: 3 Bar
Exhaust: Stock Manifolds, 3" Downpipe, No Cat, 3" SS
Fuel Pump: Hot Wired 255 LPH installed by the previous owner
Distributor: New E-bay special
Wires: New Taylor
Plugs: New UR6
Intercooler: ATR Upper and bigger pump
Wideband: NGK AFX wired into the ECM (Programmed linear values into generic WB )
Fuel Pressure: ~42 LBS at idle with vacuum hose attached. Hard to tell with Harbor Freight Gauge as it was jumping around.
Possible problems I thought of:
-Still have some bad gas. I drained out all I could and pumped out some more. I added 5 gallons of fresh 93 but there was some left.
-Bad ground. Might be missing one from the batt to the body but I did ground both heads and added an extra from the head to the body. I did notice that the batt voltage seems a little low at the ECM (12.8-13.4).
-Tried to adjust throttle body blades to get IAC counts in the 40's as they were very low. Also looked for intake manifold leaks with carb cleaner. Didn't notice shifts in idle RPM but it is hard to get under the intercooler.
-Pilot bushing is loose rattling around at idle it is causing tons of false knock.
-Vacuum hoses are all new or in good shape but I guess there could be a vacuum leak.
randy merritt
Re: New Setup, Working out bugs, Could use some help.
email sent. have you read the powerpoint presentation on Code 59 tuning? Good starting point.
Randy,
Thanks for the .bin. I'll give it a shot and see how she responds. I have read the Code 59 powerpoint a couple of times now. I also read a book on tuning EFI and think I have an okay feel for what to do. Although, as I am discovering, there is no substitute for actually getting in there and doing it yourself.
Randy, I didn't have time to try your bin until yesterday. It did behave differently but I essentially got the same result. Had to lower the BPC in table F28 all the way down to 115 in order to lean out the AFR to ~13.0:1 or so at idle.
Any ideas?
randy merritt
my truck likes to idle at a 13:1 afr or so. Every build is different, and that is the AFR that works best for me. If it idles good, I would go with it (proceed, I mean). you might try taking a little fuel out at higher rpm's, as my build flows a bit more air.
I took the Adj. FPR apart because I thought the diaphragm was old and cracking. It looked fine to me.
Top Side
Bottom Side
It idles well at 9.5:1. Once I lean it out to about 13:1 the idle starts oscillating and the truck will occasionally die.
I may need to move my posts from 59.org over here. I don't even think anyone besides Paul is looking at them over there.
took apart the fuel pressure regulator and the diaphragm was in good shape. I did however find a problem with the fuel pressure. I had previously checked the fuel pressure with the vacuum hose connected and realized that I should have done wo with it disconnected. With the vac hose pulled off the AFPR and plugged with my thumb and with engine at idle and it was in the high 50's. I dialed it back to 42#.
I then let the truck warm up and adjusted F28 trying to get near 14.7:1 again. It started in the 9.0:1 range and was idling very smooth. As I leaned it out the AFR started to oscillate and the idle got rougher and rougher. I compared my F28 values to other 60# bins and my values were way low. I was around 128 to get a ~14:1 AFR. I thought maybe my WBO2 was lying to me and took F28 up to ~170 and the idle smoothed out again. WB showed 9.0:1. I checked NBO2 and values were in the high 900 mV range and no crosscounts. Grr. I then leaned it out looking for ~450 mV on the NBO2 while keeping an eye on the WBO2. I never got steady readings on the NB but when I started to get crosscounts my F28 values were back down around 135 and it was running rough with the occasional backfire out the exhaust. When reving at idle with BPC values at 128 it gets really rich again.
Any ideas???
Well I double checked the balancer mark to verify if it is really at TDC. As far as I can tell it is within +/- 1 degree. I grabbed the timing light, disconnected the brown wire and checked timing. Everything looked good unless I am getting something wrong.
I turned the truck off, re-connected the brown wire and pulled the ECM B fuse.
I decided to try another bin from a syty.net member (Thanks Randy). The bin for a truck that was quite different from mine, but we just wanted to see what happened. I set it up for my NGK wideband and it fired up without much fuss. It was expectedly very rich around 9.0:1. After a few minutes the idle was jumping around so I upped the idle RPM to 1000 in hopes of smoothing things out. It helped and i was able to go to F28. I kept lowering the BPC but it took a while to get into the 12's and 13's. The idle starts to oscillate as does the AFR. I had to lower BPC all the way down to 115 to get AFR's up to 13:1 or so. At that point it was idling very rough and died.
I am guessing there is a mechanical or sensor problem somewhere but don't know where to look. It also seems odd that I have to adjust the BPC so far to set the 'injector constant'.
Perhaps I am taking the wrong approach, but any advice would be appreciated.
TP5 logs are posted at 59.org but I can e-mail them if anyone is willing to take a look.
I keep thinking that it might be the Adjustable FPR but don't have another to install. Any way to test it.
It holds a solid 42 lbs at idle with the vacuum hose disconnected.
