Windedv6
Ty n 10s
Now that I am somewhat finished with the performance upgrades on the AWD Ty, I have decided to reinstall a stereo system in it. Even so, it should still run in the tens as I am only planning to add about 50-60 lbs. I have not professionally competed with it since 2000 and had taken my comp system out years ago, thus no tunes for the last 7-8 years.
I will be keeping some of the componets that I had in my last competition system, such as the two 5.0 PG amps that were flushed into the tail gate, the door mounted Image Dynamics 8" mid base, the Canton/Image Dynamic separates in the kicks and the Dynaudio 3" center channel flushed into the dash. I will be controlling these with the new Alpine INA-W900 audio/Video/Nav head unit.
Here is the start. I will do some updates along the way.
The whole truck was sound deadened back in the day with Dynamat Super Lite. Since it was never removed that job is already done. The complete interior is dynamated including firewall, roof, doors side panels, etc. The truck carried this extra weight when it was running 10.60s so no new additional weight with this...
I had taken off the custom door panels that housed the Image Dynamic 8" mid base drivers a few years back and had put original panels on. The mid base drivers and the door pods on the custom door panels weight an additional 10lbs per door over the stock so we will be adding 20lbs here. When I had taken off the custom door panels I had to cut the molded fiberglass sealed enclosures away from the door panel itself. At that time I left the molded enclosures in the door. I now only have to glass the seams back together to have the sealed enclosures functional again...
Pic showing the cut seam between the door panel and the molded inner door enclosure...
Pic showing the seam re-glassed back together...
Pic of the installed custom door panel with the leather wraped speaker pod/panel on the bottom of the door. This door length, one piece, speakerpod /panel acts as a dampener for the 8" driver...
Pic of the Image Dynamic 8" mid base driver back in its place...
Pic of fabbed billet speaker grill with cloth covering...
Mid base door setup back together...
I had not taken the kicks out so there is no new additional weight added here. These were a special order 5.25 inch kick pod from Q-Forms. They originally made 6" pods for the S10 trucks, but I felt that they were to big. Since they were one of my sponsors, they made me a smaller leather wraped 5.25" kick pod to fit the truck. They house a Canton silk dome tweeter and an Image Dynamic 5.25" mid range driver...
The little stub coming out of the floor can be remove and my swing-out door bar for my roll bar setup slips in there over a pinned shaft for track day...
The center channel speaker is flushed into the dash. It is a 3" dome tweeter from Dynaudio...
Center channel speaker with grill...
This completes the front stage setup of the truck. I will continue with the amps and sub setup next week. Hint...it is light weight and trick (maybe bordering a little on the hoky side though). We will see how it works out...
John
John
