New Toys
Ian Turgeon
Cascading Inspiration
Thats Amore
Got it in today, burned a bin after a bit of fumbling around with com ports. I'll get it hooked up to the truck later this week to see how the emulation/aldl reading works.
I gotta figure out how to stack bins on the different chips.
93ty475
Re: New Toys
if you're using tunerpro, just hit F5 to bring up the bin stacker/splitter....you have to set your layout parameters, an output file, then layout each bin and click stack.....i haven't physically done this but when playing around with the layout parameters, a bin size of 16k, chip size of 256k and block size of 16k, gave me 16 different positions to stack bins.....maybe JS will chime in and tell us how it's really done....
edit: check out this page for more information
Ian Turgeon
Re: New Toys
Yea, I am using tunerpro's stacker, nice program, I just not clear on what size chips I can use and how to set up the stacking util.
Our bins are 16k, so I figured you start with that. I dont know if the chip size has to match the chip or if it can be smaller. Also assume the block size should be the size of the bins, but not sure about that..
Re: New Toys
I haven't done much stacking myself. Only time you would need to is if you plan to run an ultimate hardware.
With autoprom, ostrich setup and tuning usually you are only using 1 program anyways.
Ostrich does have some bank switching capability though, somewhat like stacking.
Mark just updated tunerpro the other day again. You can now select regions on tables and adjust.
Keep your eye on the xls file on nwstp also, we are updated that almost daily now.
Jeff
Ian Turgeon
Re: New Toys
With the autoprom I think I plan on burning chips and running off those most of the time, I'm trying to spend some time getting used to TunerPro after using diacom and datamaster for all this time, not to mention I have to pick up on the tuning portion of all this as well as chip burning. I love the ostrich, but the single cable pass-through for the aldl/emulator is what really caught my attention. Chip burning was a good bonus too so that I can help out some of the locals.
Sweet stuff so far, I was going to spend some time digging through the definition files but I feel at this point I'm probly behind the game on being able to add any input.
sytyguy
Moderated User
Re: New Toys
This is common knowledge, but it may help someone else.....
The 27C020 or 27C2001 chips (@ 256k) would require 16/16kb bins stacked or 8/16kb bins stacked and loaded into upper half. 29F040 (@ 512k) would require 32/16kb bins stacked or 16/16kb bins stacked and loaded into the upper half. Of course, the 32 bin burn would negate the lower 16 because the switcher will only accomodate 16 programs. FWIW, if you're not comfortable loading binary code in the upper half (setting start/stop point), just mirror the bins (upper/lower) and it'll work just the same.
As Jeff said....this is only an issue if you desire to run an Ultimate/G3 style setup. Personally, I emulate until I get 1 bin, then burn (doing this periodically to accomodate small mods & weather changes). But I do have customers that like the Ultimate setup.
Maxtor
Re: New Toys
I have an assembler, splitter, and a 1 to 16 (makes 16 replicas) program that all run out of a DOS window if anyone is interested in them. Very easy to use.
Re: New Toys
Keep in mind also, the autoprom can't yet emulate and ALDL until a bug is fixed.
You can do one or the other but not both. I know Paul is throwing bribes to get Mark to fix it. Has to do with how noisy our ecm is when connecting.
93ty475
Re: New Toys
mark,
can i try it? any intructions? utwtire@ gmail.com
thanks,
sytyguy
Moderated User
Re: New Toys
Just ordered my Autoprom so that I can do more vehicles in less time (AutoProm in one, Romulator in another). Too bad it's OoS until the 25th. :(
Hood
Re: New Toys
I can't get rid of my ostrich now. Although it doesn't burn chips, I could care less now. I don't plan to even run a chip anymore on my vehicles just buy an ostrich for each car.
Jeff
Ian Turgeon
Re: New Toys
the autoprom had me gleaming the minute I saw moates prototyping it. The ostrich is awesome as well... one day I may have one as well...
Now I'm gonna have to take tuning $tips$ so I can scrounge up a wideband.
crashing_sux
Blow Me?
Re: New Toys
You guys with an Ostrich doing anything special to get the aldl support to work? I have a Moates USB ALDL cable and I cannot get the ALDL monitoring to work. At the connect screen it just never connects.
Re: New Toys
I use a normal 2 transistor serial cable with my ostrich.
Connects fine, after you hit the silence ECM command a bunch of times.
crashing_sux
Blow Me?
Re: New Toys
I don't remember seeing that command, I specifically looked for it a few days ago when I started tunerpro last. My build is only a couple of weeks old, are you using build 4.00.2137.00. The only specific command I see to send is "Mode 1 ALDL Dump Request", do I have to manually setup this silence ecm command?
