skwayb
NWSTP
For all you Tuner Pro users, I have a new Tuner Pro ALDL def up for the SyTys on www.nwstp.com. It fixes several problems in the ads file.
Here is the file:
1227749 2&3bar Code 58 ADS
The file contains the following changes:
1) changed sync BPW calc. TP4 does math as: ALDL_val*factor or factor/ALDL_val
Therefore, the old value was BPW inverted. I did the math (1/65536)*ALDL_val
2) changed async BPW calc. Same as above
3) Timing with respect to DRP and Timing with respect to TDC were swapped.
I changed the ALDL byte numbers to correct it
4) MAT A/D value. The MAT tables were inverted. Fixed those also. Added output for Both Degrees F and Degrees C.
5) VE formula fixed
6) Calcs for 2 Bar and 3 Bar for MAP and Boost Added (Calcs both done in kPa and PSI)
7) All MALF FLAGS were made visible
8) All MISSING FLAGS have been added. (Bytes 57,58,59,60,61,62 and 63)
I tried to fix all the problems that have been reported. If you find anything in this recent ads file, let me know and I will get it corrected.
Here is the file:
5) VE formula fixed
