NEW - Weldon Fuel Pump - up to 1000hp
V-loci-T
PICTURES AT BOTTOM OF AD.
WELDON C2015-A Fuel Pump - $560 (Paid $695) Specs Below)
FUEL PUMP SPECS:
This has -12 inlet / -10 outlet
Maximum HP:
1000 hp @ 14V EFI (500 hp on Methanol)
1050 hp @14V carb (525 hp on Methanol)
GPH/PSI Range:
85-115 GPH/0-160 PSI
Features:
-- All billet body pumps are 100% serviceable/repairable
-- Self Priming
- Pump may be mounted above fuel cell, vertical or horizontal mount
-- Breakaway coupling prevents pump/motor damage in the event of contamination
-- All internal wear components are 100% metallic
No plastic materials. Our internal pumping elements are made of high speed tool steel and bronze. This results in the longest lasting, highest quality most durable pump available.
-- Body machined from billet aluminum
-- For carbureted or injected engines
-- Provides Consistent Performance with no fall-off in flow
-- Precise fuel delivery
-- Blades self-compensating for wear
-- 5.5 lbs
Current Fluids
Weldon Pump offer the widest range of fuel compatibility.
Gasoline - Methanol - Nitromethane - Diesel - Ethanol - All racing fuels
I have 400 positive feedback on ebay under "4degreeslower". If you have any questions let me know.
