new zq8 steering box source
ircwet
Re: new zq8 steering box source
I Just wanted to say that the autozone 7525 "jeep" box went in perfectly, no hitches whatsoever. I also installed a new pitman, idler, tie rods and adjuster sleeves at the same time. Thanks warmpancakes for the heads up. Much nicer than the old set up for sure 110%.
How much was it?
13.robb
As far as adjusting sleeves, i just went with the factory style for the moment. I as well will be doing the ball joints and control arm bushings in the near future, just have to do some at a time as i am daily driving at the moment.
As far as price, i had a total of $270 for the gear, all tie rods, adj sleeves, p/s lines and a radiator. I got them at jobber price. so add 30% +, - for reg price. the gear box is about $130 plus core retail.
roswald21
You wanna do a write up/ breakdown on the part numbers for the ones who have idiots at our local autozone
Davemc1963
93 Ty Owner
Good info Guys
Just to add a little more info. After a very quick search, I came across the Hollander Interchange number of 551-01690. This appears to be for 96-98 Jeep Grand Cherokee's.. I dont know what the difference is between the 92 - 95 models and these though.
sypwrdss
My 96 SS S10 has the ZQ8 box. From what I know, ALL SS and Extreme S10's had the ZQ8 suspension package. Hence the RPO Code : ZQ8
aasltmike
Wait... there are Autozones that aren't staffed by idiots?
-P
Don't come to the Autozone in Hinesville, GA...staffed by idiots and slower than a glacier. I got my ZQ8 from a local salvage yard out of a 2000 Xtreme, IIRC. Real snappy response and firmer feel to the steering, even with the stock bus driver steering wheel and stock front end.
0-60N4
I got mine from Autozone for '98 GMC Sonoma 2WD, ZQ8. Perfect. 2.5 turns lock-to-lock compared to 4.5 for the stocker. $139.00 life time guarantee. The ZQ8 box, Jeep steering shaft, improved column bearnigs and 13.5" steering wheel compared to the stock 15" makes it drive like a totally new vehicle. What a great improvement. Don't know why I waited so long to do this but I am glad I finally did.
sy605
Can you elaborate on the improved bearings for the steering column? Are they sealed? Source?
Thanks
fivetodrive
CRISPY
Aren't all of these boxes a 12.7 to 1 ratio with the differences between the zq8 and Cherokee just the internal stops?
0-60N4
bearings: The SyTy originally came with only a rubber bushing in the column, just above where the steering shaft attached. Bad design. It gets hot and deforms givng no support. There's a new design with a harder bushing and an actual bearing. Easy replacement if you are removing the steering shaft.
the new part numbers are:
7805700 and 7805822 about $40 for both.
Mprt Kla
Jim,
I have the jeep shaft, does the bushing/bearing still work with that if your not using oem shaft?
-Neil
