Newbe to chips
OK, Datamaster and cable are coming. Once I look at/post some runs, get feedback and the thing is running correctly I want to put in a chip.
Yes, I've searched and seen the posts on "just buy the Untimate".
Still the question is, on a stock motor (stock turbo, stock -full time- IC, stock injectors) with the potential for high flow cat and ATR exhaust do I buy the Ultimate or can I save the $$$ and buy the 10in1? It seems the only deference is how many programs, some of which I wouldn’t use anyway because of the stock motor.
Thanks much,
Don
TYTILIDIE
METH HEAD
Re: Newbe to chips
Im glad you asked cause I was wndering the same thing. After looking at all the features it seems the 10 n 1 is a good buy but maybe someone has some better input with experience.
Mike
SeattleSy#1255
Category 5 Conservative
Re: Newbe to chips
THe differences are major...one is a 2 bar the other a 3 bar. You want more boost, you'll want a 3 bar chip.
read up on the differences between a 2 bar and 3 bar chip. That'll answer most all your questins. I had some good links, but with the new board i can't find stuff anymore. LOL
TYTILIDIE
METH HEAD
Re: Newbe to chips
Read it already. Im thinking the 10n1 looks pretty nice. Anyone used it and the Ultimate and compared?
Mike
Re: Newbe to chips
Just to be clear, here's Todd's answers to my questions:
Thank You Todd...
1) Just to confirm is the 10 in 1 a 3 bar chip?
No, it's to be used with the stock 2 bar sensor
2) Either way for a stock Sy (stock turbo, IC and injectors) it seems to me that the 10 in 1 saves me money and gives the performance improvements of an Ultimate. In other words aren't the additional programs mainly for modified motors?
The differences are minor for your list if mods, although it does give you a wider range of boost control. If you do add a turbo or other significant mod later though you'd want these benefits.
Todd
SeattleSy#1255
Re: Newbe to chips
basically if you want to run more boost/be faster then you'll want to go 3 bar. However that is not to say you won't be faster with a different chip running same boost levels with a 2 bar.
i'm just saying... it is just basic, more boost more power faster times.
