Newbie help w/ DM file
jds_sy
Guys, long time Sy lover, lurker for a bit, and finally bought a truck. Read a lot about data collection and decided I needed some data on the truck to know what issues I have.
Truck is all stock, never been chipped and has 33,790miles. I ran into a KR of 12.5 and let off the gas..to many posts about anything over 4-5 being really bad. However I had to get a understanding of issues, so I guess that isn't to bad.
So I have plugs, wires, cap on order but wanted some insight on what else I might have going on. I noticed a boost of 15 twicie once w/ a KR of 5 and then at 12. It was a short run, barely got thru 2nd. (been reading http://powertuneplus.com/syclone/howto_stock13s.shtm)
Any help on the file and other possible things to look/fix would be helpful. jdsstreet is highway driving (normal) and jds1 is the WOT run almost thru 2nd.
http://boom.net/~jds/sy2352/jdsstreet.uni
http://boom.net/~jds/sy2352/jds1.uni
Thanks in advance
-jds
WyoSyclone
Re: Newbie help w/ DM file
I just looked at your logs. On the one labeled jds1 you've got a lot of KR (up to 12.5). If I were you I'd pull/replace the plugs, wires, cap, and rotor.
It seems like finding TDC on #1 and checking the balancer for slippage is a rite of passage on these things. Then you can check the timing and make sure someone hasn't dinked with it.
You'll want to get a fuel pressure gauge on it and check to make sure pressure is rising 1lb for every lb of boost.
It wouldn't take long to damage it with repeated runs with that amount of KR.
jds_sy
Thanks for the input. I'm already on the pace of plugs, wires, cap, rotor replacement however they were done 400miles ago, which was about 4yrs ago in this trucks life. :lol:
Anything else funky? RPM shitfing? voltage? Idle? Boost curve? IAT?
I'll start w/ that and the TDC slippage and get timing checked so its at 0. From there I will rerun and post. It wont be till next weekend as I am going fishing next week.
Thanks guys.
