newest DM run
Mike
I took out my ultimate chip because i was getting a constant 2-12* knock. I put my stock chip and 2 bar map in with the base FP set to 50. Here is my newest DM run. Im still getting a little knock, but nothing like it was before. Could someone take a look at it and let me know what you think .... http://www.mediafire.com/?dqluaxjgwud
silverblaz
Re: newest DM run
hey i looked at that DM run now i am not a tunner by any means i but i am a mechanic and by looking at that run you have a serious problem your readings are ALLLLLLLLLLLLLLL over the place.... look at your coolant temp its bouncing all over the place your IGN volts is only 9.2 you have really bad ground problem or bad voltage problem ... something to that effect figure it out you have some major issues going on there
91blazins10
Re: newest DM run
I didnt see any of this? His engine temp was 167 the whole time, and the ign volts only dipped down to 13.3. I would check for something rattling around causing false knock.
WyoSyclone
Re: newest DM run
The 1-24.uni file doesn't look too bad. Your engine was barely up to temp for the run (161f)..... If you were attempting a full-throttle run, which I'd think you were by the shift points, your TPS values only reached about 84%... might want to check to make sure the cable end on the throttle plate cam hasn't slipped out of its hole and make sure a floormat isn't binding the throttle up. It's running closed loop, and nothing about the run looked dangerous...
