Re: no boost.. what could the problem be?
Take off the DP and actually look at it??
well I took the rod off and I can move the flapper (what the rod attaches to on the exhaust housing) with ease. The wastegate actuator I can't move by hand but think that's normal. Next step is to put my air compressor to the vac line connected to the actuator and see if it closes/opens I guess.
You have an fp and boost gauge? Anything abnormal? Any data files?
Yeah I have data logs but can't upload them from work.. and the only thing wacky is the fact that no matter how much TPS I throw at it the wastegate duty cycle stays at 100% which is weird and also shows that the wastegate isn't opening but I can hear it opening because it's loud as hell.
The iac only changes from or two 6 or 38 but haven't looked back on clean logs yet to see if that's normal but out side that there doesn't look like there's anything bad.
Idle in park = bad and in drive = ok?
Only thing that changed then is tc load.
Yes that's correct, in park idle is a little too high like 1100 or 1200 ish. In Drive it sits perfect at 850 but I did get an iac error code 35 a few days ago and i've never changed it in this truck so im pretty sure the idle shit has to do with the iac and will replace that once I find the issue with not having boost.
The trans shifts very firm still just like the day I got it so I dont' think it's the trans or anything.. watching my rpms I don't see any slippage either.
This damn issue all started when I swapped back to the atr chip (which worked great for a few days) and jammed the ecu back up into its resting place.. im thinking maybe something got pulled or cut.. hmmmmmmm
Thanks for the ideas, keep em coming
